rear climate not working
I don’t have the climate control package but in my car the second row vents work as long as the mid (torso section) air-flow option is selected in the climate options menu. The back vents don’t work when only the lower (foot section) option is selected. It took me a while to figure this out. Hope that helps.
Ehloo - Can you post pictures of your Defender? I would like to see your tire and wheel combination. Sounds great
I need to figure this out too. It seemed unusually cold inside my Defender and I finally saw that the rear temp dials were set to 60. Turning up the rear controls to 70 solved that issue. My LR4 has a button that allows the rear temp to sync with the front temp OR allows the rear passengers to set their own temp. I need to dig into the manual to see if a sync function exists for when I'm driving alone.
