Rear door fixed window is loose (behind functional window)
Old Nov 25, 2022 | 12:03 PM
dogwind's Avatar
Default Rear door fixed window is loose (behind functional window)
The whole window piece not just the square decorative piece
I started getting intermittent wind noise (depending on how the door was last closed I guess)
While heating the car one morning with fan on high, I came out to car and could hear fan wind whistling out the back side of the panel I circled.
I can lift the back edge of this window and see the round clips that should pop into holes in the door frame not seating.
If I were to continue to pull it up I'm sure it could be ripped off and gain access to the vehicle.
I ask here because I may not understand the construction/adherence of this part.
Proper fix?
In case they just try to fist bump the clip back in its frame hole or randomly start applying glue?
I am not referring to the decorative "square" that is on the rear part of the fixed window - referring to the whole window panel
Bob
Old Nov 28, 2022 | 12:49 PM
dogwind's Avatar
Default Dealer will replace - no recall but this is definitely a problem
Old Nov 28, 2022 | 11:57 PM
nashvegas's Avatar
Well it certainly seems like an easy way to break in (even if it's not detaching itself). Very odd.
Old Nov 29, 2022 | 07:39 AM
MattF's Avatar
It'll be curious as to what the actual failure is. Seems like it might be an adhesive fail or miss application.
Old Sep 21, 2023 | 09:45 AM
Landy718's Avatar
I too had the same issue, and had it in to my dealer to have it repaird. The problem is I now have a whistle at speeds over 60mph. I've had it back to the dealership twice - they claim it is fixed but the whistle persists.
Had anyone else had this issue? I can eliminate the whistle with some carefully placed tape, but I'm not interested in driving around with a taped up window. The dealership seems clueless and clearly isnt test-driving the vehicle to check if the issue is resolved.
Old Sep 21, 2023 | 10:47 AM
mrego's Avatar
Ask their technician or SA to jump in the car with you and show them the whistle. They won't be able to deny it then.
Old Jun 29, 2024 | 02:40 PM
EchorecT7E's Avatar
Does anyone have a TOPIX subscription and could share the bit on replacing the 2nd row fixed window? Mine is also coming apart and ordered a replacement. I am out of warranty.
Old Jun 30, 2024 | 10:05 PM
gts944's Avatar
I think my dealer just applied some sort of window urethane adhesive. No issues 2 years out.
Old Jul 2, 2024 | 02:56 AM
CptRandlelwa's Avatar
3rd Gear
I have exactly this issue on my Defender - anyone know what the fix is?
It's a 2020 so out of warranty.
Old Jul 2, 2024 | 07:37 AM
Groundhog413's Avatar
It's a known issue. They have replaced both of mine. I would inquire with your service department.
