Rear door windows and mirror folding question
Old Apr 17, 2026 | 03:18 PM
L460_Rocks's Avatar
Default Rear door windows and mirror folding question
In your defender 110 or 130, how low do the rear windows go? In my '26, the passenger side sticks about 1.5" above the door line and the driver's side goes down almost all the way down into the rear door.
And the auto-fold of the exterior rear view mirrors, any way to disable this when locking the car or only with an OBD tool?
Old Apr 17, 2026 | 03:27 PM
DGINAZ's Avatar
I believe there is a setting in the PiviPro to control if the mirrors fold when locking or not. I can't recall the rear window height when all the way down - I don't believe they go all the way down.
Old Apr 17, 2026 | 03:29 PM
wcc18999's Avatar
The rear windows do not go all the way down. And yes there is a way you can disable the auto folding mirrors when locking the car. I had the dealer do it on mine. Perhaps someone with an OBD tool can chime in for instructions.
Old Apr 17, 2026 | 03:31 PM
wcc18999's Avatar
There is no setting in Pivi Pro to disable the folding of the exterior mirrors; however there is a setting in Pivi to lower the mirrors when reversing.
L460_Rocks's Avatar
I found the setting only for the tilt-on-reverse. No auto-folding on/off option.... as for the rear windows I found it strange they park at the fully open position at different heights.
Old Apr 17, 2026 | 05:02 PM
Myron's Avatar
But only if you have memory seats. My 90 has manual seats, so no memory settings, and the mirror dip on reverse is linked to the memory seat feature.
Old Yesterday | 10:21 AM
yong264's Avatar
5th Gear
If no options are available in the menu, you can only use an OBD tool to disable the mirror-folding function.
Change "MULTICAN 703 (mirrors)"And"EUCD 085 retractable mirrors yes/no"
Old Yesterday | 10:28 AM
yong264's Avatar
5th Gear
You could try manually pushing the window glass down—that’s what I did—and then simply operating the switch a few times; that should get it working normally again. However, I still recommend contacting the dealership to handle it, since it’s covered under warranty.
LR disco 5
Sep 14, 2022 07:01 AM
Pdflrd
Feb 27, 2022 03:14 PM
devildollnyc
Jun 1, 2020 01:59 AM
Davis31052
Aug 15, 2017 09:52 AM
avking
Jan 16, 2009 05:44 AM
