Rear wiper replacement?
Old Nov 28, 2022 | 11:58 AM
POPTOPP's Avatar
Default Rear wiper replacement?
The existing rear wiper blade seems to be hollow through which the wiper fluid is pumped. I haven't been able to find a replacement of this type. Hate the idea of going to the dealership to get the blade replaced. Anyone found the correct replacement?
Old Nov 28, 2022 | 01:45 PM
MattF's Avatar
Bosch Wiper Blades Fitment Guide
Old Nov 28, 2022 | 02:07 PM
POPTOPP's Avatar
Bosch is my go-to brand. However, the OE Specialty Rear wiper, is incorrectly listed as a fit. It is a solid blade, not a suitable replacement for the integrated washer system of the factory blade. Note the washer line to the blade and the attached rubber tube with the spray holes. Unless I'm missing something from the Bosch site, I didn't see a replacement.
Old Dec 5, 2022 | 11:53 AM
MattF's Avatar
Follow Up to this post. @POPTOPP is correct regarding the Bosch rear wiper replacement. I ordered Bosch A334H and it does NOT have the windshield spray capabilities as the OEM does. The Bosch front wipers (BOSCH Snow Driver 24SD Winter Wiper Blade - 24") fit perfectly.
Old Jan 5, 2023 | 01:24 PM
nashvegas's Avatar
I have a 2020 110 X w/ cold climate pack, and the factory original wiper blades, so it's 2 years old & time to change wiper blades. 2 questions:
1) Need to remove the spare tire to change the rear blade (like on my old Discovery 2's which I always found annoying)? I can't figure out how to get the wiper blade off, the service manual shows just pulling it towards the window away from the arm.
2) I'd remembered reading this thread about the wiper blade being "special" to incorporate the squirters, so was expecting that when I went to change. However, when I opened the dealer part box, just a normal rear wiper. Just as I was about to get hot and bothered, I looked at my car, and indeed I have a regular blade with no squirt function, ie standard style squirter separate entirely from the blade. So that's good. (ie I have no tube connected to end of wiper blade and little micro holes in the wiper blade to squirt the water out, like the photo above). I googled this and it's called the Valeo Aquablade, used on Volvos etc. Did Land Rover try this and then abandon it on the Defender ? Or is this something that was added to later Defenders? Doesn't really matter just curious really.
Old Jan 6, 2023 | 08:04 AM
GrouseK9's Avatar
It's times like this I wish @The Insider was still around. Many times people would ping him as if he were the JLR Grief Box or HelpDesk. I just liked his insights into the "why's". Regardless, I think we'll never know.
Old Jul 27, 2023 | 03:52 PM
gdyear78's Avatar
Hi, did you ever figure out how to remove the rear blade? I am in the same boat, and cannot find anything on it! Taking the rear tire off seems silly for replacing the wiper blade.
Old Jul 28, 2023 | 07:52 AM
Ratledge's Avatar
Since we're talking about wiper blades, my rear does what I expected and puts fluid all across the rear window when I use it.
The front pair seems to only spit at the farthest extent, and no fluid anywhere else.
Is that adjustable? Don't see it if it is (or is that normal?)...
Old Jul 30, 2023 | 12:23 AM
joeg679's Avatar
I have an issue with my front wipers too. I had a bug hit my windshield on the driver's side, so I pressed the button for wiper fluid and it only squirted out a little, from each blade and never got and fluid on an entire section of windshield, directly in front of my face. Is there a known issue with this setup? This definitely won't be fun in the winter with salt all over the windshield.
Old Jul 30, 2023 | 06:31 AM
Defendit..'s Avatar
