Recovery loop steps
Old 03-06-2023, 08:47 PM
spritekk's Avatar
Default Recovery loop steps
Looking for a recovery loop rear step that is roughly the same round size as the loop.
I thought I saw someone had that step in 'what did you do to your defender' thread, but couldn't find.
I've seen Simon's, but I don't want a step that is quite that large.
I tried searching the forum, and couldn't find.
Old 03-07-2023, 06:39 AM
Mike_F's Avatar
Powerful also makes a smaller one, designed to protect a dog’s paws. Might be too small to make a comfortable step but worth considering.
Old 03-07-2023, 09:01 AM
GrouseK9's Avatar
Received 1,279 Likes on 764 Posts
@Mike_F provided the link to the latest PowerfulUk. It seems like it should work. I've gone thru quite a journey with these. First I had a friend make one. This was way back. (Post #19 on this thread Link). Then PowerfulUk came out with their version. This actually works well as it helps provide a second footing when pulling gear down or getting onto my Rhino Ladder. Only thing to note re: the PowerfulUk "larger" step is that you REALLY need to know which side you want. They come standard for the right hand side, even their diamond plastic plate. They will switch it to left, but you have to ask and if you get the plastic diamond plate, you will have to do some "modifications" with a forstner's bit. I thought about going with the "hocky puck" insert, but I have big feet and don't want to wear climbing shoes<g>. But, you do you and I'm sure it will look cool/work for you, either way. Good luck! Post pics if you get one as I'd love to see them in the wild.
JustOne
Defender
09-28-2022 01:08 PM
p400_au
05-24-2021 04:04 PM
NickAdams
02-27-2013 08:11 AM
slanginsanjuan
02-06-2013 01:10 PM
landRoverNewbie
10-13-2009 12:26 PM
Quick Reply: Recovery loop steps
