Remote Climate Control is severely lacking
I don’t understand how $100,000 car doesn’t give you the option to control seat heaters, steering wheel heaters or even turn on the actual heat within the vehicle. Every time I use the climate control the car, it is not warm when I get in it even though it says that the climate is on high heat in the app
2021 Defender X
2021 Defender X
Last edited by Ledeutsch; 03-10-2022 at 08:57 AM. Reason: Adding vehicle info to thread
100% agreed. I just wish it had simple key fob activated remote start with auto cool or heat functions like all our jeeps have had. i don't even bother using it anymore as the app usually has logged me out, or fails with a generic error, or even if it starts i really did nothing but wasted fuel because the air coming out is still freezing (vehicle is always parked in my garage).
I've only used it a few times, but I've always had good luck with it. Both in cold and hot conditions, it has worked well.
The app is definitely a bit slow - takes probably 30 seconds to get it to load and connect with the car, but it has consistently worked. I don't recall there being specific control for the heated steering wheel (mine doesn't have heated seats), but it does turn on the heated windshield in cold temps.
2021 Defender X
2021 Defender X
The other thing that I can’t stand is the fact that the fob has to be about foot away from the door for the button on the door **** to unlock. So if I have my fob in my pocket I have to lift my leg up closer to the door **** in order for the door to unlock. My Jeep Cherokee had a much better range for the fob as well as the auto start was far superior with regards to the climate control.
@rutiger - Can you describe what "works" means? I know that's a dumb question, but so am I! I have completely given up on the fob. Or the remote aspect of it. I just hit the buttons and party like it's 1999 (er, 2009). Do you mean that you walk up and open; close and walk away? Do you have to press the little rectangle on the handle? Can you describe what it now does that you like? Act like you are explaining to my/your mom....
GrouseK9 (03-10-2022)
Got it!! I gave up on that just because of the wonky way I would have to enter a left hand drive: Open door with my right hand and do a ball room dance move as I spin around clockwise to get in. Or open with my right hand, step aside and piroutte. It's brilliant for right handed, right side drivers. For right handed, left side drivers (none of who work in a British design shop) its wonky.
Ok, now that I understand. I'll take my 1st world problem and go get a latte... Glad it's fixed for you. I'll keep going old school, like the curmudgeon I am! Note - I was secretly hoping that the proximity would do it and I could open my left hand drive door with my left hand.
