Replica Stainless Steel Rear Bumper Scuff Plate
Old May 13, 2021 | 09:25 PM
clb87's Avatar
Default Replica Stainless Steel Rear Bumper Scuff Plate
I ordered a replica Stainless Steel Rear Bumper Scuff Plate on eBay a few weeks ago. I believe it is supposed to resemble VPLEP0447, although I'm not sure the OEM one has a rubber border like mine does. It shipped from China and was not supposed to arrive until June, but it was delivered last week. It smelled a little strange when I got it but I let it air out a few days and installed it this evening. I have not been able to compare it to the real thing, but it looks pretty good for $125! Should keep the dog from scratching up the surface when he jumps in the back.
Old May 14, 2021 | 02:56 AM
Defendit..'s Avatar
It looks pretty good indeed, and stops scratching.
But it is still slippery, that concerns me with the metal plate. ( original or counterfeit )
With the set checkered set VPLEP0419 made of ABS, curious if that stays / will be anti slip / non skid when wet.
Old May 14, 2021 | 06:09 AM
mreloc's Avatar
Great find! Did you try the magnet test? I have hesitated ordering the OEM one figuring there must be a more reasonably priced alternative.
Old May 14, 2021 | 08:54 AM
johnsonmc2000's Avatar
Rimmer Bros had a reasonable price on the OEM item. Just got mine yesterday and will fit in the next few days. Thanks for the pics. Was looking for a good shot of how it would look
Old May 14, 2021 | 01:26 PM
Juancl's Avatar
Do these get glued to the bumper?
Old May 14, 2021 | 02:25 PM
NoGaBiker's Avatar
I imagine they have peel-off double-sided automotive trim-tape on the back, but I'm just guessing.
Old May 14, 2021 | 05:03 PM
charlypm's Avatar
Correct.
LAND ROVER ACCESSORY FITTING INSTRUCTIONS
Old May 14, 2021 | 09:05 PM
majl's Avatar
Good looking pup! 🐕‍🦺
Old May 14, 2021 | 10:19 PM
TheMoke's Avatar
Stainless steel can be magnetic or non magnetic, Testing using a magnet does not determine whether the stainless steel is good quality or not. It just (loosely) determines the type of stainless.
Marine grade stainless is not very magnetic for example. Yet it is very corrosion resistant.
Another **** factoid is that non-magnetic stainless steel (I forget the correct name for it) can vary in its magnetic properties. Refrigerator doors for example can be a little more magnetic on the side where the sheet of metal has been stretched by the panel pressing machine.
It’s amazing what BS one can write after a couple of glasses of wine. I shall shut up now. 😁🍷
Old May 15, 2021 | 02:48 AM
NoGaBiker's Avatar
I thought he meant to see if it was plastic or not.
