Roof Antenna Aerial - Broken
Old Jun 5, 2023 | 06:20 AM
basel's Avatar
Unhappy Roof Antenna Aerial - Broken
Yesterday I touched the antenna fin and it broke ... fortunately the electronics under no damage ... where can I find the product code and the cost of the replacement? Thank you.
Old Jun 5, 2023 | 07:10 AM
lightning's Avatar
For this you will need to contact your Land Rover dealer. Hopefully the plastic cover will be available as a spare part without the internal components.
Old Jun 5, 2023 | 08:09 AM
Defendit..'s Avatar
When I moved back the aerial, the cover is bolted from behind the underside with 8 torx screws
Old Jun 5, 2023 | 08:18 AM
basel's Avatar
however, there are 5 versions ... it will not be so simple to guess the correct code
LR070768
LR097274
LR140900
LR117613
LR140901
Old Jun 5, 2023 | 10:53 AM
AAJR's Avatar
Typically if you enter your VIN, it will tell you the correct part number. You might try LR dealer parts sites from other countries (not sure where you are).
Old Jun 5, 2023 | 01:06 PM
basel's Avatar
But I don't know where to insert in VIN ...
@Defendit.. which APP are you using? I see you have prices in Euros... I live in Italy
Old Jun 5, 2023 | 07:53 PM
AAJR's Avatar
Prova qui. Puo essere necessario utilizzare una VPN situata negli Stati Uniti.
https://parts.landrovercary.com/
Anche questo posto: https://www.scuderiacarparts.com/car...parts_483.html
Old Jun 5, 2023 | 08:02 PM
WTFChuck's Avatar
‘I touched it, and it broke’. Well, if you were my neighbor, No, you can’t borrow my lawnmower.
Old Jun 6, 2023 | 12:27 AM
basel's Avatar
Old Jun 6, 2023 | 02:40 AM
Defendit..'s Avatar
Scuderia , you can do a VIN check there
https://www.scuderiacarparts.com/par...486/4937/92345
