Is the Roof Rack just too loud?
you can install a custom wind fairing. it will help but you will always have wind noise. most of the noise comes above 65
i took mine off as i was not using it enough. it does look good while on
If you are not traversing remote areas or strapping serious cargo to your roof I'd encourage you to consider our cross-bar solution. They are intended for most normal situations on the street and are far quieter (and a bit more fuel efficient).
GrouseK9 (03-16-2022)
Once again, totally agree with @The Insider . He of course comes with the actual manufacturer experience, but this is likely true of any vehicle that has a rack and, worse, gear up there. I don't put fault to JLR about the wind noise with the rack, that's just true of all of them. Anything added to the well tuned body lines will cause friction to mpg and increase in road noise. Once you pack stuff up there like some of the "Off-road Hooligans" (one day I'll create an image/patch/sticker) then you make it worse.
markjlr (03-16-2022)
