Roof Rack Options
Install Started Well Sort Of
Due to the weather things have been a little delayed. The first of four boxes finally arrived today and as luck would have it this box was the main rack. The box looked a little worse for wear but the parts inside were mostly good to go. There was a couple small spots that the black had been worn off but nothing big nor to really worry about. I bet I do more damage myself putting stuff up there once mounted.
Boxes
The rack went together nicely. I have everything together without loctite at this point. My plan is to put all the roof mount bits on and mount the rack to make sure everything lines up properly. Then I will go around and loctite and tighten everything. Will also wait for final adjustment of the extra crossbars for when I mount some ROAM cases. The light mounts will get moved into final position once the rack is on the roof. Included picture just to show what it all looks like and how it fits together.
Here is the progress so far.
Boxes
@inater is the wind deflector on your rig the frontrunner item? Same with the light bar mount?
Light bar - https://www.roughcountry.com/product...ar-72940blkdrl
Deflector- https://www.frontrunneroutfitters.co...mm-1255mm.html
richmeyer (01-30-2024)
More Arrived
At this point I am starting to think this is going to be a very slow process. Apparently customs is going to clear one box per week. Four boxes total with two delivered. A week between them. So it is looking like it will take a month to get the whole order. Today the aero conversion kit arrived. Still waiting on the floor panels and most importantly the vehicle mounting parts. Put a couple more bits together just to see how it is fitting together. Fit and finish are very nice.
Aero front fitting parts.
Added a Camel Trophy sticker.
Looks great! I wanted to order it since it was launched a while back but there were very few pictures on the site. Does the rack require you to modify anything to the vehicle? Can you open the sunroof? Cheers👍
