Routing cables from roof to trunk
Old 07-13-2024 | 11:58 AM
Doug3's Avatar
4th Gear
Default Routing cables from roof to trunk
Hi, I was planning on mounting one of the Starlink Mini’s on one of the back wings of the expedition rack, then routing a USB-C cable into the trunk — what’s the best way to route a cable inside through the back of the car?
Old 07-13-2024 | 05:28 PM
tbrown's Avatar
@PowerfulUK has this video of mounting the Plumb side boxes:
During it, Simon shows a grommet that is up high. I'd try and use that. Although you might need a new panel, as they seem to break easily.
Old 07-13-2024 | 05:57 PM
Doug3's Avatar
4th Gear
https://www.youtube.com/watch?v=QufLL9uTib8
Awesome! Thank you. Any tips for where to route the cable into the panel when I remount it?
Old 07-13-2024 | 06:48 PM
zac431's Avatar
https://landroverforums.com/forum/20...lution-105438/
I've pulled that panel on a couple of defenders now and haven't broken one. You could probably just glue it back together.
Old 07-13-2024 | 07:10 PM
Doug3's Avatar
4th Gear
thanks! Would I need to drill through the factory roof rails? Or do you think there’s room to slide the cable into the pillar plastic when I re-attach it?
Old 07-13-2024 | 07:16 PM
zac431's Avatar
I'm not 100% sure, but I think you would have to drill the rail. I'm using the front runner rack without roof rails. It leaves a pretty big gap and I haven't had any water leaks. So I wouldn't worry about a adding hole to the rail.
Old 07-14-2024 | 08:16 AM
DefenderSISU's Avatar
Default Roof rack lights
2 Gromits going into the body
Don’t do this they put it in the wrong place I wanted it on the back plastic piece so that way it would not Pierce the roof.
This is plastic so it’s ok to go here.
Huc (07-14-2024)
Old 07-14-2024 | 02:46 PM
Doug3's Avatar
4th Gear
thank you! So I can drill on through the top plastic of the back top panel plastic as the recommendation?
Old 07-22-2024 | 07:55 PM
Defendeth's Avatar
Do you know what gauge wires you were able to fit through?
Old 07-22-2024 | 08:07 PM
zac431's Avatar
I ran a a pair of 10 awg wires that had pretty thick shielding and there was plenty of room. They were for solar. You could probably fit larger wires with a bit more effort.
Quick Reply: Routing cables from roof to trunk
