Scratches on 18" rims P400 Brakes
I recently converted my P400 from 20 to 18" rims and noticed after some trips in the mud that I'm seeing some small grooves on all 4 rims. Very shallow. I expected some given the tight clearance and muddy terrain that I've been planning on visiting. Front right where no brake mods other than removal of the mud-scraper was done has the worst damage. I want to say ~0.5mm deep by 2mm grove has been carved by a rock between the front caliper and the rim.
I knew this was a risk factor associated with the change to a smaller rim but had figured it would be the rears where the clearance is tighter, 2-3mm following the caliper trim, versus the front where there is a more normal ~5mm I guess.
It would seem, a smaller gap prevents bigger pebbles getting lodged.
I don't think the groove is deep enough to compromise the integrity of the rim but wondered if others, having done a similar mod to their P400/D300 had noticed anything similar on their rims.
What is the thickness of an alloy rim in that internal area? anyone know? I've been googling to no avail. I know it will vary from rim to rim of course but figured there was a typical range. I'll touch base with Tuffant and see if they have the specs. I'm hoping there is some 4-5mm of Aluminum there.
The tolerances on the 19"rims is very close on the rear calipers also.
I was just wondering if this is a normal consequence of muddy off-roading fun. Some grooving of the rims.
Thanks very much for chiming in with your own experience. I guess my thread title is a little too specific. Hadn't thought of the 19"s
Haven't looked at the exact clearances of a P400 with 18's. Curious if you could fabricate something akin to the wheel scrapers used on rally cars. Metal mount with replaceable silicon or plastic material the remove snow/mud/etc.
Of course, if the wheels are simply too close to the caliper (after grinding or replacing with the smaller caliper), that's a different story...
OEM on 20"s comes with a mud scraper on the fronts. This scraper is not on the OEM 19" setup. Its removed to fit 19's or 18's. It's a close fit with 18"s.
Curious if other members of the "P400 rollin' on 18"s club" have noticed anything similar on their rims.
As I said. I was watching the rears closely. Turns out the fronts are the ones taking more of a pounding.
Switching back to my 20s for my winter rubber soon. I'll snag some pictures of the damage then.
mdgs (11-09-2022)
They're close. Real close.
Just parked next to a Ford Expedition with 275/65/18s... how does a truck the size of a 130 Defender fit an 18" rim and not a 110? I think JLR has some pathological level delusion that only big rim Defenders are desirable or something. I'll convert my 19"s if it is a problem... but I'll give it a go for a while first.
Gavin, I just checked all 5 of my 18s (I have the 20s on the Defender now and the 18s in the garage), not a sign of even a scratch, let alone a gouge like you have. Mine are OEM steelies, though, so far from an apples to apples comparison. Also, I don't do much mud/snow/slush work compared to you; more dry rock and gravel and dirt/clay. But I do wind up in the muck from time to time.
The following 2 users liked this post by NoGaBiker:
curb-optional (06-07-2024),
GavinC (06-07-2024)
