Selectable ARB rear locking differential progress
Old 03-15-2023, 04:48 AM
sarek's Avatar
Default Selectable ARB rear locking differential progress
A few more progress shots on the selectable rear locker project. 3d printed case half turned out pretty good! A few more tweeks in the model and then we move on to a working billet prototype! 😀
The following 12 users liked this post by sarek:
Can_Glu (01-19-2024), GrouseK9 (03-17-2023), jusmax88 (03-15-2023), markjlr (03-15-2023), MattF (03-15-2023), mdgs (03-16-2023), mopadzi (03-15-2023), pinion (04-03-2024), RenoDefender (03-15-2023), Ronin Defender (03-15-2023), TrioLRowner (03-15-2023), WAFOX (04-03-2024) and 7 others liked this post. (Show less...)
Old 03-15-2023, 09:49 AM
Ronin Defender's Avatar
Any idea what the cost will run installed when completed ?
I haven't gotten stuck yet but would rather have a helping hand when I do..
The following 2 users liked this post by Ronin Defender:
GrouseK9 (03-17-2023), markjlr (03-15-2023)
Old 03-16-2023, 06:49 AM
sarek's Avatar
Not quite at that phase yet. The good news is there will be no drilling required. Basically just remove your differential swap out the carrier and install our new case half. The nice thing is that the only shimming that will be required will be for Carrier preload. The simple method will probably be to have a diff shop install. We will be offering full installation at our shop. We will also be offering in a kit form for other shops to install and even diy
The following 3 users liked this post by sarek:
GrouseK9 (03-17-2023), pinion (04-03-2024), Ronin Defender (03-16-2023)
Old 03-16-2023, 08:00 AM
Air or electronic locking engagement ?
Old 03-16-2023, 08:53 AM
Trauma's Avatar
ARB's are air lockers, so a pump/airline is required. Anyone know what percent lock up does the stock differential five? Is its performance similar to a Trutrac?
Old 03-17-2023, 02:31 PM
GrouseK9's Avatar
Received 1,279 Likes on 764 Posts
I am one of your biggest supporters on this project. You may single handedly prevent me from having to install an e-Diff! Let me know if you start a Kickstarter campaign... I may have to be an early supporter!!
Old 03-17-2023, 03:33 PM
sarek's Avatar
Air locker
Old 03-17-2023, 03:39 PM
sarek's Avatar
Stock differential is a conventional open diff. Not like a true trac or torsen style diff. Optional Factory electronic diff has clutch packs and a ball ramp style flat motor. It is a variable locking torque on demand style differential. The traction control system ultimately controls how much locking there is. Based on terrain mode selected and feedback from the vehicle. Both factory style differentials have a single pin in the differential.. ARB has a cross pin which is a lot stronger.
mopadzi (03-21-2023), TrioLRowner (03-20-2023), WAFOX (04-03-2024)
Old 03-17-2023, 03:41 PM
sarek's Avatar
I appreciate that. You are always welcome to send me money 😀
The following 2 users liked this post by sarek:
GrouseK9 (03-21-2023), Ratledge (04-02-2024)
Old 04-02-2024, 10:32 AM
ryanjl's Avatar
Is there any update to this?
Quick Reply: Selectable ARB rear locking differential progress
