Selectable ARB rear locking differential progress
Old Mar 15, 2023 | 04:48 AM
sarek's Avatar
Default Selectable ARB rear locking differential progress
A few more progress shots on the selectable rear locker project. 3d printed case half turned out pretty good! A few more tweeks in the model and then we move on to a working billet prototype! 😀
Old Mar 15, 2023 | 09:49 AM
Ronin Defender's Avatar
Any idea what the cost will run installed when completed ?
I haven't gotten stuck yet but would rather have a helping hand when I do..
Old Mar 16, 2023 | 06:49 AM
sarek's Avatar
Not quite at that phase yet. The good news is there will be no drilling required. Basically just remove your differential swap out the carrier and install our new case half. The nice thing is that the only shimming that will be required will be for Carrier preload. The simple method will probably be to have a diff shop install. We will be offering full installation at our shop. We will also be offering in a kit form for other shops to install and even diy
Old Mar 16, 2023 | 08:00 AM
Air or electronic locking engagement ?
Old Mar 16, 2023 | 08:53 AM
Trauma's Avatar
ARB's are air lockers, so a pump/airline is required. Anyone know what percent lock up does the stock differential five? Is its performance similar to a Trutrac?
Old Mar 17, 2023 | 02:31 PM
GrouseK9's Avatar
I am one of your biggest supporters on this project. You may single handedly prevent me from having to install an e-Diff! Let me know if you start a Kickstarter campaign... I may have to be an early supporter!!
Old Mar 17, 2023 | 03:33 PM
sarek's Avatar
Air locker
Old Mar 17, 2023 | 03:39 PM
sarek's Avatar
Stock differential is a conventional open diff. Not like a true trac or torsen style diff. Optional Factory electronic diff has clutch packs and a ball ramp style flat motor. It is a variable locking torque on demand style differential. The traction control system ultimately controls how much locking there is. Based on terrain mode selected and feedback from the vehicle. Both factory style differentials have a single pin in the differential.. ARB has a cross pin which is a lot stronger.
Old Mar 17, 2023 | 03:41 PM
sarek's Avatar
I appreciate that. You are always welcome to send me money 😀
Old Apr 2, 2024 | 10:32 AM
ryanjl's Avatar
Is there any update to this?
