Setting TPMS light load not possible
I've set it, @Easy3 . Could be your Software Update/version. First, try restarting your Defender. If that doesn't work, you may have to wait until the next patch. Might fix it, might not. The best route is always to do the most painful: Dealer.
Got it set at light load!! Can’t exactly tell how it happened but I was playing with it a number of different ways, and when I started it up the next time the warning messages were all gone, and it is now showing the light load setting.
Keeping my fingers crossed that it won’t revert back to the other setting.
Cheers
Cheers
TrioLRowner (07-06-2021)
Same issue
Same problem here. I set to heavy load and am unable to set to light. My right rear dropped into the warning zone and I’ve been trying all sorts to set to light load to clear it. Thinking I’d put air back in to clear it and now I’ve got this oddity. Right rear has more air than left but still only warning on the right. Landrover needs to get their s*** together with software. Constant bugs.
Boo
02-01-2014 12:09 AM
