Show us your aftermarket wheels
Old Jul 2, 2021 | 11:00 AM
DallasBBQ's Avatar
Originally Posted by GrouseK9
@DallasBBQ - Any rubbing issues? I'd like to go BFGoodrich K02 275/55R20's on my stock rims with the 1.5" Johnson rods but worrying about rubbing. Likely go with 30mm spacers to help but would like to avoid if needed. Thanks for any insights.
Zero rubbing. Tires and wheels fit fantastic. I really like the wider look as a result of the wheel offset. I'll try to take additional picks if it ever stops raining in Dallas.
Old Jul 2, 2021 | 11:53 AM
GrouseK9's Avatar
Thanks, @DallasBBQ The vossen wheels are likely better with the off-set. I'm sure someone else out there with the BFGoodrich K02 275/55R20's have them on my stock rims with the 1.5" Johnson rods. If someone has this setup, let me know if it rubs or you recommend the spacers. Thanks.
Old Jul 2, 2021 | 03:25 PM
MrBreeze's Avatar
How's the noise? I ran the same Nitto's on my Ram 2500 diesel - love the tire, they were louder than stock, but with a clackety diesel, it didn't really matter. The Defender is a much quieter ride, so curious as to how the Ridge Grapplers were.
BTW, did you also consider the new Nitto Recon Grappler when you chose to go with the Ridge Grapplers?
Oh, and where did you get the Vossens? Any deals to be had or is it pretty much MSRP?
Old Jul 2, 2021 | 03:43 PM
DallasBBQ's Avatar
I'm really surprised how quiet the Ridge Grappler rides given the aggressive pattern. I looked at the Recon Grappler but didn't like the design as much as the Ridge Grapplers.
Regarding Vossen. I was able to get about a 15% discount off retail by using a local dealer listed on their website. Vossen is 100% MSRP when dealing directly with consumers.
Old Jul 2, 2021 | 04:28 PM
zac431's Avatar
Tuffant 18 steelies ET27 offset. No lift rods, no spacers. OEM TPMS sensors fit. Currently running the OEM all-terrain tires.
Old Jul 3, 2021 | 10:14 AM
p010sp0rt8's Avatar
Not quite aftermarket. but I had my car wrapped in matte PPF and rims bronzed
Old Jul 5, 2021 | 11:54 AM
dj200's Avatar
Just a heads up: Lucky8 is now packaging their brake conversion kit with Redbourne Alston in matte black or gloss white.
https://lucky8llc.com/collections/de...brake-calipers
https://lucky8llc.com/collections/de...calipers-white
Old Jul 5, 2021 | 12:01 PM
MrBreeze's Avatar
Interesting - I have been considering a set of satin bronze Vossen HF-2 https://vossenwheels.com/wheel/hf-2/ to go on my to-be-built Gondwana Stone 110 X
I'm thinking the bronze wheel might be a good tie to the body color. Seems like bronze wheels have been making a come back as the new cool. I remember them from the late 70's Pontiac Trans Am...
Old Jul 5, 2021 | 06:25 PM
crewcabrob's Avatar
These are Hercules wheels by Redbourne in size 20x9.5. Running Yokohama Geolander MT G003 that are 33 x 12.5 x 20
Rob
Old Jul 5, 2021 | 09:01 PM
dj200's Avatar
^^^ Are you using lift rods?
