So I added the upgraded angel eyes drls...& going to add AFS Adaptive Eurospec lights
#21
#22
Trying to clear up some confusion and preparation on the chance you’re flown out to the east coast.
to enable matrix lighting the following is required (please confirm or correct)
1-premium LED headlights (either ordered with the truck or added on after)
2-euro spec LED ballasts for the NA spec lights
3-you to code the matrix lights
is this correct?
is this correct?
#23
is this correct?
is this correct?
The following 3 users liked this post by EasternShoreDefender:
#24
#25
I've actually been very interested in doing this so I'm curious to learn from anyone that has tried. I was really disappointed they didnt offer matrix headlights in the US and I don't think it's a cheap modification but I want it! 😄
@sarek Do you have any thoughts on installing matrix headlights on a US defender? If I bought German or French matrix headlights could you make them work?
GrouseK9 (12-08-2022)
#26
EasternShoreDefender (12-03-2022)
#27
I did the same, I had the base LED spec lights and switched them out for premiums however I’m having issues getting the proper brightness on the Halo ring.
if I went to the Land Rover dealership will they be able to program my defender to accept the premium lights?
thanks!
thanks!
I had to buy the upgraded lights on ebay. Then my dealership had to code the lights to work with my lower grade spec. I found two lights for 300 each. The additional Eurospec ballasts were 150 each.
The difference between the USA NA high spec lights versus the Eurospec Adaptive AFS lights is pretty cool. I bought the Eurospec ballasts and I will need to swap them out and have them recoded again at the dealership but it would be pretty cool to have the only USA spec with cool Adaptive AFS headlights.
https://www.youtube.com/watch?v=UmahzP4MZxY
#29
I’m not sure on initials but I purchased the premium, not the matrix. I’d like to do the CCF change myself, can you give some guidance on the tools needed to perform?
