Software update today.
Thunderbob, would please explain how you navigated to that screen in your post? I usually just check to see if there is a Pivi update, didn’t know you could check on app updates. I would like to check my system for that info, also. Thanks.
I believe that's just the "live apps" like weather, AQI etc updating themselves, but it would be new (at least on mine) that I got a notification for that. I don't recall ever seeing a notification on these "live app" updates.
Anyway that screen doesn't show a Pivi main OS (ie 3.3.3) software update. Even where it says "Software updates" that's just for the apps. To check that you'd go to the main Pivi settings menu, hit software update and you'll see a version like 3.3.2 or so.
UNLESS they've changed it ! Which is quite possible.
The following 5 users liked this post by is21447:
Elektrapops (06-28-2023),
MattF (06-26-2023),
Ratledge (06-29-2023),
StormRover (06-25-2023),
WTFChuck (06-24-2023)
I didn't notice any manjor changes to the 3D surround camera views but the added Orange and Red distance warning markers for the reverse camera are handy.
Can't recall if the yellow trajectory lines ran ahead of the car in the overhead camera/obstacle view before this update.
I put a piece of black tape (you can see it just behind the car in the image above) on the ground and backed up until the new Red warning indicator lined up with it.
The farther Orange warning line shows the minimum distance where the rear door can still swing open unobstructed.
Here the new Red warning line lined up in the picture above looks like this from the side:
If you drop straight down from the rear spare tire, you'll have just over 4" to the Red warning line (that was lined up to that black tape on the ground) clearance wise.
Hope that makes sense.
