Spacers to avoid rubbing?
Old Apr 14, 2021 | 07:08 AM
SmokinV10's Avatar
Originally Posted by Ehloo
my shop was trying to push me on the 275/60/20 settup but hearing the possible issues i was glad i went with the 55 series instead.
the 60 do look so much better. No matter what some inner fender modification will need to be done. it could be as simple as trimming and pushing back the liners with zip ties etc. pretty common stuff when going with bigger tires
this was all new for me also. never had a lifted truck with big tires. learning a lot as i go
i have the 1”, 1.5” and 2” lift rods. The 1 and 1.5 ride similarly but the 1.5 helps with clearance. The 2” rides worse and actually causes the tire to rub MORE as the centerline of the wheel is placed closest to the front mudflap
Old May 1, 2021 | 01:40 AM
Defensor's Avatar
Replacing PR’s 1” kit with JR’s 1.5” kit helped. It’s very close but it doesn’t rub anymore. Normal height:
Old May 2, 2021 | 09:26 PM
Penquinn's Avatar
Before you fit spacers ensure they are legal in you area. They are outlawed in may places. I would also do a deep dive into their safety. Lots of folks (engineers/mechanics) are not friends of spacers.
Old May 3, 2021 | 11:01 PM
BBS's Avatar
BBS
Are you looking to get off-road with those wheels? I don't think those Vossens (while pretty) are designed for that! Certainly those Ridge Grapplers are good for it though!
Old May 5, 2021 | 09:01 AM
Defensor's Avatar
No with these wheels. I am changing them soon.
Old May 6, 2021 | 04:39 PM
spikemd's Avatar
Sorry to be off topic, but is that the Lucky8 ladder with full-length FR rack? I was worried it wouldn't fit. Please confirm.
Old May 17, 2021 | 03:45 PM
Victor Bravo's Avatar
8th Gear
Vossen are some of the strongest well built wheels out there. If they build for your car they have tested it.
Old May 17, 2021 | 08:16 PM
8th Gear
Default Vossens
If you are looking to switch up this set up message me I might take them off your hands
Originally Posted by Defensor
good point. I do like how it looks like with this setup. I will look at modifying the inner fender as well.
Old May 18, 2021 | 05:56 AM
aao4473's Avatar
Default Rubbing with the 275/55/20
I am facing the same issue, I tried installing BFG 275/55/20 on my Redbourne alston wheels but they were rubbing and I didn't want to trim anything, whats confusing is that even if I raised the defender into offroad mode, it still rubs.
So im not sure if the offset of the wheels is creating this, and would a lift solve the issue (my dealership officially stated that any change in the suspension such as adding lift rods will void the warranty immediately) which sucks as there is no way to lift the defender for bigger tire.
My wheels specs are:
20x8.5
Offset 25
Back spacing 5.730
Old May 19, 2021 | 10:02 AM
8th Gear
It seems the Offset needs to be 30 & up.
