Specs of 5098 style 22 wheels??
Can someone share the specs of the Land Rover Style 5098 22 wheel?DIAMETER: ?
WIDTH: ?
OFFSET: ?
BOLT PATTERN: ?
The CPO Defender I just bought has these and Im looking to downsize to the LR style 5094 20 wheels and want to make sure it is a compatible swap without mods. Thanks! Great info here!
WIDTH: ?
OFFSET: ?
BOLT PATTERN: ?
All OEM rims regardless of diameter have the same offset +41.5mm and bolt pattern. 5x120,
18" are 8" 19, 20" are 8.5" and 22" are 9"
All 20" will fit on any Defender regardless of trim/engine/brake caliper size. Straight swap with the 22"s. No issues.
18" will only fit D200, D250, D240, P300
19"
19"
[QUOTE=GavinC;894149]All OEM rims regardless of diameter have the same offset +41.5mm
[/QUOT]
@GavinC Just for future readers, I stumbled upon two separate references that say the 22 wheels are actually a different offset at +43.0mm. Below is the reference from the Land Rover online iGUIDE for the Defender. Please forgive me if I am wrong.
So, if this true, and I do swap out my stock 22 wheels for the Style 5094 20 wheels (+41.5mm instead of 43mm offset) what would be the effect of changing offsets? Would it be noticeable?
[/QUOT]
[QUOTE=longtrip68;894579]
Thats news to me. Apologies for the bad info.
1.5mm more not going to have any fitment issues.
there are a gazillion examples of people swapping OEM 22s for 20s and vice Versa.
no issues whatsoever. 20s fit on all Defenders. No exceptions.
[/QUOT]
[/QUOT]
