Steering Wheel Pulls on its own
Hey so my 2020 defender 110 hates median walls, I live near a stretch of road outside my house where its a 3 or 4-foot high median wall for about a mile, and even with the lane assist button off the steering wheel becomes really erratic pulling away from the wall back and into the right lane next to me, since its as my leave my house it happens daily. Is there any other thing I'm missing to turn off? it's really a pain
Hi @seanscores have a look at the link below, hopefully it helps
https://www.ownerinfo.landrover.com/.../proc/G2781345
The steering wheel button doesn’t disable the Emergency Lane Keep Assist that needs to be done in the vehicle settings, there’s a fair bit of reading material regarding Lane Keep Assist, Emergency Lance Keep Assist and general driving Aid safety in the owners manual under the Drivers Aids:
https://www.ownerinfo.landrover.com/...section=T23993
Mine does the same thing intermittently at a certain median near my street. Good luck with the settings, I've never had any luck with a setting that turns it off, or if there is a setting it doesn't remain off following a restart.
If I had to pick my most annoying features, and the numerous steps it takes to disable them, only to reset upon every restart, is the Emergency Braking, and Emergency Lane Keeping. I always disable both of these before driving, since I don’t like my vehicles slamming on the brakes when it’s not necessary, just because I’m slowing behind a car making a right turn into a parking lot and I’m gauging the speed and distance, safely, only to have the Emergency Braking activate without warning and I fear the person behind me rear-ending me. Or when I’m merging into a new lane and I have to fight the steering wheel to go where I want to go. Disabling these two features requires something like 8 taps on the touch screen and 4 different screen views. Other vehicles I’ve owned took one push of a button to disable each feature. I wish JLR could configure the software to allow the driver to create a ‘Shortcut’, similar to what you can do with your iPhone. A ‘Shortcut’ that you could create and customize to combine all those taps into an icon you could name whatever you choose, and also allow you to select its function frequency, such as ‘Run Shortcut at Startup’ or require you manually activate it.
