Stuck in PiviPro 3.3.2... Not Updating
Old Jul 13, 2023 | 12:24 AM
  #31
Matty79's Avatar
You are very likely 110% correct - I forgot about those. (T-Mo and AT&T all have their own managed wifi networks around too). And yes - Wireless CarPlay does use WiFi - the vehicle has to be wifi hotspot capable (even if you ordered yours without the hotspot, it's just software disabled which is why you can turn it on via CCF). You'll notice if you have a vehicle that was ordered with hotspot - if you disable the hotspot in Pivi, it'll warn you that wireless CarPlay won't work any longer.
Wireless CarPlay uses Bluetooth to exchange commands, etc. using existing BT protocols, and a closed wifi network for exchanging other data (application data, maps, streaming music as it's higher quality than BT, etc.)
That makes sense that if your phone keeps trying to join hotspots that the carrier has pre-programmed, it would cut out.
Old Jul 13, 2023 | 10:11 AM
  #32
MattF's Avatar
As a point of reference - I'm on 3.3.2 with Auto-Join "on" and never have any connections issues with Car-Play.
Old Jul 18, 2023 | 08:27 PM
  #33
dj200's Avatar
I just got the 333 update (OTA), so if you’re still waiting for it, I’m sure it will come eventually.
In any case, there isn’t much in this update.
Old Jul 19, 2023 | 10:12 AM
  #34
mrego's Avatar
I wish I could go straight to 4.0 and get the Carplay maps in the IDD at once. That's the most useful/significant update IMO. I think it happened to me in the past and I jumped one of the updates straight to the last one. Hope that happens again, but not holding my breath.
Old Jul 20, 2023 | 06:00 PM
  #35
Okie_Defender's Avatar
OTA update to 4.0.0 today. Had a 5+ hour road trip so perhaps that helped??
https://landroverforums.com/forum/20...-117838/page3/
Old Jul 20, 2023 | 10:29 PM
  #36
dshark1's Avatar
Can someone please tell me how do you connect to your home Wi-Fi or outside Wi-Fi? Just cannot seem to find the option to do so! Hoping to receive the new update to cure my problem of CarPlay, constantly disconnecting, even while plugged in via USB-C. I have tried resetting the system, deleting and re-connecting my iPhone with no joy. I am really trying to avoid a visit to the dealership! Present software version 3.3.2
Old Jul 20, 2023 | 11:40 PM
  #37
swajames's Avatar
Here you go:
settings > connectivity > WiFi > add network
Old Jul 21, 2023 | 12:16 AM
  #38
dshark1's Avatar
Originally Posted by swajames
Here you go:
Thank you , but I tried that. I am not being given the option to add network?
or at least I don’t see it.
Old Jul 21, 2023 | 12:28 AM
  #39
WAFOX's Avatar
wifi needs to be turned on first
Old Jul 21, 2023 | 09:15 AM
  #40
micmcm's Avatar
Default UPDATED No Wifi BTW
FYI I have been notified that 3.3.3 is downloaded and ready for install twice, and did the Needful also twice (closed all windows, locked car, let it sit overnight)- to no avail. Next day start up the car and it's still sitting at 3.3.2.
This is the first time I have had any install failures. The 1st notification was like 3 weeks ago, install failed silently ie no message waiting in the AM in PiviPro; then it re downloaded it or similar 2 days ago, same result- nothing happens.
Anyone else?
(..FWIW btw none of my prior updates occurred over any Wifi connection, not sure why some keep saying that. The car HAS wifi option-- but never connected to any wifi network. All updates prior came strictly OTA and installed same way (Close all windows, lock, let it sit.)
