Sunroof Creaking Noises!!!
Old Jan 22, 2022 | 02:00 AM
Dmedenas's Avatar
Default Sunroof Creaking Noises!!!
Anyone else dealing with the sunroof creaking and cracking when vehicle body is flexing at low speeds? Tends to especially be much more noticeable at colder temperatures. If you have experience similar issue anything you did to help eliminate the noise?
Thanks!
Old Jan 22, 2022 | 03:12 AM
Ritson's Avatar
Its the rubber seal, same issue with the doors. I took mine back to the dealer and they applied silicone lubricant to all seals and the noise has now gone. Will probably need doing every few months but is an easy fix
Old Jan 23, 2022 | 06:15 AM
johnsonmc2000's Avatar
Thanks!
I have the same. Not 100% sure it’s from the sunroof but it is from that area - top right in my case. I’ve tried what Rustin suggested by no change. I’m following this with interest.
Old Jan 23, 2022 | 06:50 AM
CombatNinja's Avatar
Apply silicone lube liberally to all the rubber seals in the roof and doors. It will quiet your Defender down significantly. This big box definitely has some flex in it.
Old Jan 23, 2022 | 07:48 AM
PaulLR's Avatar
Clean the rubber gasket with isopropyl alcohol. Then apply Honda Shin-Etsu grease:
Amazon Amazon
Same silicone I used to stop my 1988 Honda Accord sunroof seals from squeaking.
umbertob
Oct 19, 2021 09:14 AM
KTI
LR2
May 15, 2021 12:53 PM
dr. mordo
Apr 3, 2016 07:08 PM
And4848
Dec 10, 2008 02:40 PM
TrickyWhu
Mar 9, 2007 11:38 AM
