Tasman 110 w/ Rotiform STL's + BFG
Old Jul 20, 2022 | 01:46 PM
GavinC's Avatar
Aren't these 20" and steel?
Must weigh a fair chunk.
Old Jul 20, 2022 | 02:11 PM
CombatNinja's Avatar
Are these the exact same wheels the Vulkan Automotive sells?
Old Jul 20, 2022 | 09:21 PM
gtbeale's Avatar
Originally Posted by 2thebrim
Where did you get them from?
https://www.wheellab.us/rotiform-stl...-r19120902161/
Pretty sure they are forged aluminum, but let's be honest it's a big wheel so it has some weight. Then again so did the stockies.
Looks like the center cap area is a bit different
Old Jul 20, 2022 | 10:22 PM
NoGaBiker's Avatar
Forged? For real? Our GT4s didn’t even come on forged alloys (they’re cast.) Which is not to say the Rotiforms aren’t forged — I don’t know anything about them. But five of them are going to be $8-10,000 if they are, I bet. And 20” forged wheel should way around 20# or less in our widths.
Old Jul 21, 2022 | 06:45 AM
MattF's Avatar
Cast monoblock
​​​​​​https://www.rotiform.com/wheel/65233.../?styleID=4200
Old Jul 21, 2022 | 03:32 PM
There is a forged STL from Rotiform staring at $1500. Each. Assuming most sets you see are going to be the cast aluminum version. 37 pounds for 20' x 9' in case anyone is curious. So probably not far off from what the stockers weigh. They are not exactly light.
Old Dec 22, 2022 | 07:41 PM
Lbj9189's Avatar
Default STL fit
Greetings,
Question, the center bore of the Roitform STL is 72.5 mm, the L663 center bore I believe is 72.6 mm. Was there any issue with this difference? Thanks
Old Dec 22, 2022 | 08:19 PM
gtbeale's Avatar
Originally Posted by Lbj9189
Greetings,
Nope all good
Old Dec 27, 2022 | 05:41 PM
2thebrim's Avatar
Greetings,
I have the 18” version of this wheel and I have had a slight issue with the center bore of the wheel being slightly smaller than the L663 hub. I don’t think the 0.1mm would cause the issue and I’ve measured the center bore of the wheel, which is true to mfg spec. Saying that, I may need to increase the center bore ever so slightly after I get the brakes sorted to get everything fitted.
Old May 27, 2025 | 10:08 PM
Fenouz's Avatar
@gtbeale just bought the same set and planning to mount them on KO3 now that sizes become available. Do you recall the lug bolt size was by any chance?
I’m assuming that the stock ones won’t work. Thanks in advance
thaddh
Apr 25, 2022 12:52 PM
4Corsa
Aug 15, 2021 08:23 PM
BAA1
Oct 30, 2019 10:13 AM
Ellingson Classic Cars
May 23, 2016 11:55 AM
savedsols
Nov 5, 2007 08:10 AM
