Those with heated & cooled seats......
Old Oct 31, 2021 | 06:09 PM
waldoverkill's Avatar
Mine has the same setup. I reckon your fan is going backwards. It should suck in that vent and blow up through the seat.
Old Oct 31, 2021 | 06:34 PM
Low Country's Avatar
I believe you are correct. The wiring must be crossed causing the fan to rotate in the opposite direction….WOW
Old Nov 1, 2021 | 06:48 AM
CombatNinja's Avatar
I agree. The cooled seats blow air out of the perforations, so that little duct should be pulling air in. Can you feel appreciable air movement with your ventilated seats if you are wearing very light clothes? I think something is definitely wrong with your installation in this case.
Old Nov 1, 2021 | 08:30 AM
Can one of you snap a similar picture like I did above showing the round fan under the seat? Thanks
Old Nov 1, 2021 | 08:54 AM
Looking and researching this more, the air actually does not suck into the elongated vent that I circled in red if all operates as intended. The air is pulled through the round puck shaped section with the white filter. So..........I have NO IDEA why air is blowing out of the elongated duct part. I'm going to my dealer to compare with another Defender.
Old Nov 1, 2021 | 11:05 AM
Update: I haven't gone to my dealer yet to compare with another Defender but.....I verified that my fan is rotating correctly and pulling air through the round filter section and indeed I can feel cool air coming through the perforations in the seat cushion......but, at the same time there is warmer air exhausting or blowing out of the elongated section I circled in red in my pictures above. Note that my climate control was totally off while I tried this. My seat fans are definitely rotating correctly and pulling air through them and into the seat cushions, question is WHY is warmer air exhausting out of the elongated duct work towards the back of my knees/calfs? I annotated the photos attached here so it explains better what I am seeing.
Once I verify with another vehicle at the dealer I'll determine if this is correct standard operating procedure.
Old Nov 1, 2021 | 11:49 AM
drcoop's Avatar
Thanks for the pics, this is really interesting to see. Crazy question, which may take someone like Simon and his team at PowerfulUK to figure out, but I wonder if this under seat fan could be fitted to Defenders that didn't come from factory with "cooled seats"? Mine has heated seats only and here in the south, could use cooling more than heating.
Old Nov 1, 2021 | 12:35 PM
That would definitely take a brainchild like Simon to answer for sure. Not sure what is involved electronically speaking.
Old Nov 1, 2021 | 05:17 PM
D-Fens's Avatar
I didn't answer because I haven't been able to test this for you, but for what it's worth:
I feel like back when I used my cooled seats I felt I small amount of air behind my knees as well, but nothing substantial, and I definitely still felt the cooling from the seat itself, which is why I didn't make much note of it. Is that elongated vent there to essentially equalize pressure depending on how high the cooling is set and who is sitting in the seat? Technically a larger person (not specifically heavier, mind you) would block more of the seat vents so maybe if a certain static pressure is reached, the excess is vented from there to save the fan from excess wear?
Old Nov 1, 2021 | 07:00 PM
Hi, Your theory is certainly valid and that could be correct. I do not believe there is anything wrong with my heated/cooled seat operation, the fans are rotating in the correct direction, my seat cooling & heating can be felt in the cushions, my whole point of my thread was to determine if air should be blowing out of the elongated duct towards the back of our knees..... but until I verify with a couple Defenders on my dealers lot I can't say for sure.
