Top rear fin?
Old Mar 7, 2022 | 07:53 PM
Xploit's Avatar
Default Top rear fin?
Is that fin thats on the top rear for the clearsight?
Old Mar 7, 2022 | 08:29 PM
nashvegas's Avatar
It has the satnav/antennas for things internally -- but yes, it's also the mounting location for the clear sight camera.
Old Mar 7, 2022 | 09:15 PM
Xploit's Avatar
So all defenders have the fin then? I have seen pictures of defenders in Europe without it, I think it looks better without.
Old Mar 8, 2022 | 12:37 PM
Brock Samson's Avatar
I have never seen one without the fin. Clearsight fin is slightly larger, but it is on all defenders.
Old Mar 8, 2022 | 12:39 PM
Xploit's Avatar
Heres one where I cant see it
Old Mar 8, 2022 | 12:43 PM
Oh, that is good to know.
I have a slight height issue in one garage I need to access, maybe it can be replaced with something flat.
Old Mar 8, 2022 | 03:49 PM
_Allegedly's Avatar
How much more clearance do you need and what kind of opener do you have? Almost all openers can be very easily adjusted to travel a little higher.
Old Mar 8, 2022 | 03:56 PM
GavinC's Avatar
I can see it.
Old Mar 8, 2022 | 08:38 PM
GrouseK9's Avatar
Any Defender (90 or 110) trim level you have built in the NAS will have that fin. If you go to the configurator, it appears that all trims levels and body styles have it because it contains all of the nav, etc. antennas.
That could have been a ROW (Rest of the World) spec or one of the many myriad options that are no longer offered.
Old Mar 8, 2022 | 10:06 PM
Thanks , but it is not a door issue, it is a low drainage pipe.
I can get under it, but only on one side, it is about 1.5 cm too low at the worst point.
