TOWING: Manual resolves tongue & hitch confusion
Old Sep 28, 2020 | 07:52 AM
TrioLRowner's Avatar
Default TOWING: Manual resolves tongue & hitch confusion
With having the vehicle comes a chance to read the manual. I see it calls out two allowed tongue weights as: a) 330 lbs (150 kg) -- being accommodated within the vehicle gross weight (6845 lbs 3105 kg) and allowed rear axle load (3965 lbs 1800 kg) and b) 771 lbs. (350 kg) -- with every pound above 331 lbs. reducing the vehicle gross weight and the rear axle load by the same amount.
Also, the manual recommends load distributing hitches NOT be used. This question was noted by a reader, earlier.
Trailer brakes are required above 1653 lbs (750 Kg).
Last edited by TrioLRowner; Sep 28, 2020 at 12:10 PM. Reason: clarifying readability
Old Sep 28, 2020 | 04:53 PM
Cobber's Avatar
3rd Gear
Thanks for the info. Is it possible to list all the weights in the manual? You've noted the gross vehicle weight does it list the gross combined weight, gross trailer weight etc? (lbs and kgs please). Does it provide any info in the manual about where to install said trailer brakes? I've seen one photo only so far where someone has installed electric trailer brake controller but wondered if there was any more about it in the manual?
Old Sep 28, 2020 | 05:45 PM
Cobber:
The manual has all the weights for all different Defender models and engines in Kg and Lbs. Which couple may I document for you?
Old Sep 28, 2020 | 06:00 PM
Cobber's Avatar
3rd Gear
Thanks for responding, I'm particularly interested in the P400 and the D300 (if that's in the 2020 manual?).
Old Sep 29, 2020 | 06:57 AM
My manual contains only the petrol engines, as the diesels are not available in North America. The weights (lbs / kg) for the P400 3.0L petrol models are:
110 5 seat: curb wt. 5035 / 2286; Gross vehicle Wt (GVW) 6975 / 3165; Gross Train Wt. (GTW) 15175 / 6885
110 6 seat: curb wt. 5090 / 2309; Gross vehicle Wt (GVW) 6975 / 3165; Gross Train Wt. (GTW) 15175 / 6885
110 7 seat: curb wt. 5165 / 2343; Gross vehicle Wt (GVW) 7160 / 3250; Gross Train Wt. (GTW) 15365 / 6970
110 5 seat: max front axle load 3370 / 1530; max rear axle load 3965 / 1800
110 6 seat: max front axle load 3435 / 1560; max rear axle load 3965 / 1800
110 7 seat: max front axle load 3370 / 1530; max rear axle load 4185 / 1900
Actual loads on front and rear axles, applied simultaneously, cannot exceed the GVW limits
110 all petrol engine types: maximum roof crossbar load (including the wt. of the roof rails and crossbars):
Vehicles with all season tires: 220 / 100 Vehicles with all terrain tires: 370 / 168
90 5 seat: curb wt. 4780 / 2170; Gross vehicle Wt (GVW) 6545 / 2970; Gross Train Wt. (GTW) 14745 / 6690
90 6 seat: curb wt. 4830 / 2193; Gross vehicle Wt (GVW) 6610 / 3000; Gross Train Wt. (GTW) 14810 / 6720
90 5 seat: max front axle load 3040 / 1380; max rear axle load 3910 / 1775
90 6 seat: max front axle load 3085 / 1400; max rear axle load 3910 / 1775
90 all petrol engine types: maximum roof crossbar load (including the wt. of the roof rails and crossbars):
Vehicles with all season tires: 176 / 80 Vehicles with all terrain tires: 260 / 118
Enjoy !
Old Sep 29, 2020 | 07:24 AM
The maximum tow mass for the P300 is 8201 lbs / 3720 kg
maximum ball mounted accessories mass is 147 lbs / 67 kg
The manual has quite a bit detail on required amp loads of each light to be sensed by the vehicle to know a trailer is attached. I think this is necessary in the new world of LED trailer lights.
Here is the brake statement:
"An electric trailer brake module connector is located near the driver's position. The information in following table should be used to confirm if an electric trailer brake module is compatible with the vehicle..."
These maximum loads are in the table:
Permanent battery feed 30A
Brake Signal 100 mA
Electric brake connection to tow bar electrical socket 30 A
The braked connector is a 7 prong round one (lots of pictures on the web). It sits beside the non-braked, 4 connector flat one.
carid
Member Group And Special Buys
Jul 22, 2016 05:56 AM
cosmickites
Defender
Aug 3, 2012 12:13 AM
cmcfarland21
Oct 31, 2011 09:39 AM
Uncle Jack
Aug 14, 2008 10:04 AM
GeoC
Jul 17, 2008 07:19 PM
