Towing specs and help please!
Old 12-29-2021 | 06:34 AM
robsonj's Avatar
yes, it’s tongue weight is quite low I believe, which is why I remembered it. Or rather it’s tow capacity is high for a suv, but not the tongue weight.
Originally Posted by Kev M
If I'm reading the OM right the trailer "nose weight" max is listed as 350 kg (772#), which is far more in keeping with the general US spec of 10-15% trailer weight on the tongue.
A mere 360# would be well under standard capacity for the tow rating of the vehicle, at least as normally calculated in the US
The Google suggests that in the UK a standard of 5-7% is used which calculates to more like 375-525# (I'm basing in an approx 7500# tow rating, though iirc actual is sightly higher). So even there 360# sounds too low.
Old 12-29-2021 | 06:39 AM
robsonj's Avatar
I must be wrong as I can’t find anything about it having a low tongue weight
Old 12-29-2021 | 06:56 AM
Kev M's Avatar
Just check the owners manual if you want to see it yourself. I did last night when I posted and quoted the max nose/tongue weight. My guess is someone missed the fact that it was listed as kgs and not lbs.
Logically speaking I can't see a vehicle rated for a high tow capacity also being rated for a wholly insufficient tongue weight for that capacity. At least not since the days of bumpers with tow *****.
robsonj (12-29-2021)
Old 12-29-2021 | 07:42 AM
TrioLRowner's Avatar
Default Read the ownersmanual to understand Defender's tongue weight
robsonj:
The tongue weight for the Defender is explained in detail in this photo from the U.S. owner's manual. Enjoy !
Read this to understand Defender's tongue weight
The following 2 users liked this post by TrioLRowner:
Kev M (12-29-2021), robsonj (12-29-2021)
Old 12-29-2021 | 03:24 PM
Kev M's Avatar
Originally Posted by TrioLRowner
robsonj:
Hmm, is that the paper version of the OM?
Interesting that it includes the US standard measurements as the online one I usually use doesn't (or at least didn't in the towing section). I had to convert all the kg's to #'s.
Old 12-29-2021 | 10:48 PM
Muppetry's Avatar
The iGUIDE has both units:
Old 12-30-2021 | 06:08 AM
Kev M's Avatar
Hmmm, where do you get the Iguide?
I've been using the OM links on the LR website.
Old 12-30-2021 | 08:58 AM
Muppetry's Avatar
It's the JLR app. You can search for it in the iOS app store or Google Play store.
Kev M (12-30-2021)
Old 12-30-2021 | 10:48 AM
michaellenzi's Avatar
Which JLR app is it? It looks there are a few of them.
Old 12-30-2021 | 10:55 AM
Muppetry's Avatar
I can only see one Land Rover iGuide on the iOS app store.
Quick Reply: Towing specs and help please!
