trailer settings
Old Nov 11, 2024 | 12:59 PM
SUPWAGON's Avatar
Default trailer settings
I have towed 2 trailers with my Defender. When I plug in the trailer plug from one of the trailers the defender recognizes that a trailer has been connected and the lights work but when i plug in the other trailer it does not recognize the trailer and the lights do not work. Anyone have any thoughts on this problem or procedures on what I can do to force a connection of the trailer to the defender?
Thank for your help
Old Nov 11, 2024 | 01:36 PM
chpsk8's Avatar
Do both trailers have the same type of lights? Incandescent or LED?
Have you tried both connections? IE the 7 pin and the flat pin?
Do you have a strong ground on the trailer that doesn't work with the Defender?
If using a 7 pin adaptor, do you have another one you can try? They are sensitive to LED (older ones at least)
Old Nov 11, 2024 | 02:01 PM
SUPWAGON's Avatar
Both have 7 PIN connectors. One trailer has LED which does not work while the older trailer has traditional bulbs.
Old Nov 11, 2024 | 04:42 PM
chpsk8's Avatar
Can you change the 7 pin connection to a new one? Is the trailer a little older? My Mercedes was a diva when it came to LED trailers. I had one 7 pin adaptor that didn't work at all and one that did.
Is the 7 pin hookup hard wired on the trailer side? Does it work with other vehicles?
dstathis
Apr 26, 2024 10:21 PM
arnoldtda
May 13, 2022 12:25 PM
Matthew424
May 7, 2022 08:02 PM
theblackfalcon
Oct 6, 2021 12:00 PM
bamarover
Apr 25, 2007 05:34 PM
