Urban fog lights came today
Old Jan 15, 2024 | 09:51 PM
Ehloo's Avatar
found another option
https://www.ebay.com/itm/37519101811...Bk9SR9bTh4aiYw
https://www.ebay.com/itm/35537028507...Bk9SR9jTh4aiYw
Originally Posted by Ehloo
there are copies of the urbans now and for much cheaper. I was debating to order a set. They make the front end look much better
Old Jan 16, 2024 | 09:54 AM
AAJR's Avatar
Search on aliexpress.com for the following: Land Rover Defender LED Fog Lamp Daytime Running and you'll see various vendors and options.
Old Jan 24, 2024 | 07:16 PM
Ehloo's Avatar
beside the cutting are they plug and play? from some of the knock off options the instructions said you have to tap into the highlight. sounds much more involved
Originally Posted by ColonelBlood
Yes they used a pneumatic grinder to make the interior frame fit. You can get their stuff at milltek in Tennessee. The lights make a huge difference in stance also in brightness. Thanks. Love this truck.
Old Jan 24, 2024 | 08:27 PM
ColonelBlood's Avatar
Default Plug and play
100% plug and play my friend
Old Jan 25, 2024 | 01:56 AM
lightning's Avatar
They do look nice, really change the look of the front of the vehicle. The standard fog lamps are barely visible (but still better than nothing)
Old Jan 25, 2024 | 02:41 PM
Ehloo's Avatar
was thinking about this, not sure if it’s truly plug and play. if the Urban fogs are now DRL they need to have a power source from the headlights to activate. the fogs only came on when your turned the fogs on
Old Jan 26, 2024 | 05:06 PM
bridgestreet's Avatar
@ColonelBlood which canard do you have on the front?
Old Jan 26, 2024 | 11:42 PM
Ehloo's Avatar
not sure if you did the install but these are not plug and play in any means.
the urban instructions below. 43 steps is a pretty difficult install
i purchased a knock off version on Ali Express. quality is perfect but no instructions.
dont know much about electrical wiring but from my research there is a dedicated plug for the oem fog light and a separate plug for the DRL. the cables appear to want to tap into the fuse box and prob a constant 12v source and ground.
any electrical gurus correct me if i am wrong
https://www.urban-automotive.co.uk/d...ll%20guide.pdf
Old Feb 3, 2024 | 04:13 PM
Default Spare delete
So badass and aggro makes the quicksilver exhaust and roof spoiler really pop.
Old Mar 11, 2025 | 03:31 AM
Txd90's Avatar
Default Any luck ?
hello
wanted to see if you had any luck with the install?
thanks
