USB Blank Plate
During the pandemic, LR installed blank plates in the rear of the center console for many Defenders. Since then there have been retrofits to get USB ports again.
Any one with the blank plates lying around? I am looking for 2x, or the part number to order them.
Thanks!
Thanks!
Yes. There are plenty of retrofits. Powerful UK sells a retrofit kit with OEM parts. https://www.powerfuluk.com/products/...b&_ss=e&_v=1.0
IIRC, JLR issued a recall and would add the USB ports when they were readily available.
Correct. The campaign number is N728. Your dealer should be able to verify the campaign for you.
Very cool, thx. Hope they let me choose what to put in those two blanks as there are 2 USB C's already. Some USB A and Cig Adapter would be good.
Part numbers for the USB-A, USB-C, 12v cigarette lighter sockets, and cover:
USB-A: LR128008
USB-C: LR150198
12v: LR144087
12v cover: LR128006
So TSB most likely won't address the other 2 blanks I'm guessing
It is plug and play. The wiring is already there. On my 2021 110, which wasn't affected by any shortages, there are two central USB-C ports, the outer two are 12v cigarette lighter sockets, and there is a USB-A port on the back of each front seat.
