Wheel spacers for the V8 defender and standard arch
Old Jul 13, 2022 | 12:52 PM
Jay282's Avatar
Default Wheel spacers for the V8 defender and standard arch
Which wheel spacer size to use for the V8 defender and standard arch, adding the classic mud flaps
Also, which manufacturer to buy from to avoid any wheel shaking etc .
Old Jul 13, 2022 | 11:41 PM
Ehloo's Avatar
sorry can’t help you in size but all defender wheels use a very similar offset wheel.
there are some older threads that will give you size. i believe it’s in the 25-30mm space to push wheels right to the fenders
just purchase a high quality set such as H&R and you should be fine. i have ran H&R on all my other cars and no issues
Old May 22, 2023 | 01:37 PM
starbai's Avatar
Did you ever end up getting any spacers? I dont have a v8, but I do have a 130 x-dynamic with the 22"... I'd like to flush the wheels/tires out a bit more before I go aftermarket some day.
All the spacer threads are on wheel sizes less than 22's.
Some mention having to shave the studs down which I will not do. I'd rather go 25mm but if 30mm allows for no shaving, I'll go that route.
Capsmy
Nov 8, 2021 09:48 AM
RR2Dfndr
Oct 27, 2021 12:35 PM
Nosugar0carbs
Defender
Dec 22, 2019 09:34 AM
Blairwarlock
Oct 8, 2019 10:35 PM
