WiFi issue
Old Nov 25, 2020 | 09:38 AM
Chris Fleming's Avatar
Default WiFi issue
When I turn the WiFi on no networks are showing up anymore... anyone having this issue? Any way to fix this or dealer needs involved?
Old Nov 26, 2020 | 04:35 PM
Freemey's Avatar
My guess is the Pivi Pro reset trick might solve this. Also the Connectivity settings could be reviewed. I have noticed that sometimes a Live App software update -not the system 2.0,4 or 2.0.5 updates destabilizes apps and connection. Lately I have not had this happen. Last application update I received was 11/21/2020
Old Nov 26, 2020 | 06:17 PM
Yea I did the reset by holding down the power button for 15sec until it resets, still didn't solve the problem though.
Old Nov 26, 2020 | 10:21 PM
Mark1107's Avatar
Mine did it too until the 11/20 software update.
Old Nov 26, 2020 | 11:50 PM
umbertob's Avatar
How about resetting connectivity? Might as well try it. Settings > All > Connectivity > About Connectivity > scroll down and touch Reset Connectivity.
Old Nov 27, 2020 | 10:08 PM
yep, I reset all that already, still no luck.
Old Nov 28, 2020 | 12:49 AM
umbertob's Avatar
Ok, you should get relevant info on the About Connectivity screen, such as the car's MAC address. IMEI #, etc. Are those fields remaining blank after a reset or do they populate with data?
Old Nov 28, 2020 | 08:05 AM
The fields are not blank, they're all filled in with the appropriate values... Before and after reset.
Old Nov 28, 2020 | 10:38 AM
umbertob's Avatar
And your home router doesn't see it? With the engine running in your garage, it should normally be listed as INCONTROLDEVICE among your router's connected devices.
Old Mar 23, 2021 | 12:32 PM
iceisarock's Avatar
3rd Gear
Any fix for this WiFi problem? I am having the same issue. 2021 110X with 2.08 software.
