Windshield Protector
#21
Have a look at Bray. They make a few windshield specific films with varying number of layers. The life of each depends on frequency of using the wipers - know going into it the film is a wear and tear item and the layers have to be peeled away every year. Ive had Bray installed on a few vehicles and am pleased with the performance. Very slight distortion of the windshields clarity but did the job.
http://www.braygroup.com/
#22
Living up in the mountains in snow/ski country I have a different view from others. It comes about from the conditions up here and what it does to windshields in general. I look at them in the same vein as tires, replace it as needed. In AZ we can get complete glass coverage for $10 a year through USAA. Now the snowplows or the semis on the I-40 like to give me the opportunity to get a new windshield almost every other year like clockwork. Usually it is a largish rock or bolt like thing that puts a nice crack or star on it. The Range Rover has had three heated windshields replaced at a cost of nothing to me. So they always appear fresh. On my 97 Defender, they replaced my windshield, again for free, due to sand erosion. Which made viewing when heading into the sun challenging. I would personally shy away from a protector, as the extreme temp changes and erosion from the cinder they put on the roads would make it less and less view-worthy. Anything plastic erodes quickly, I can attest to that from the windscreens on my aircraft. However, at least I can polish them with a purpose specified kit (about $40) and they still appear new. Plastic scratches and gets swirl marks quickly from what would appear to be nothing at all. When you clean plastic you really need to flush the surface to release any hardish items that will cause scratches when you clean it. Windshield wipers would wreak havoc on it if there was any silicate dust. I think even bug carapaces are harder than plexiglass, and it is fairly hard, has to be.
On a funny note, I went down to Phoenix to get a replacement windshield at the dealer, since Safelight had buggered up my heated one on the previous Range Rover, only half worked and they refused to warranty it. So the dealer put the new one in and I happily got on the freeway entrance to go back up the mountain, when literally ¼ mile from the dealer a rock out of nowhere hit the new windshield. So back to the dealer for another, before the sealant had even set.
The following 2 users liked this post by Dogpilot:
curb-optional (10-27-2023),
GrouseK9 (01-01-2022)
#23
Windshield film
Speaking of windshields. Picked up my 22 defender yesterday.. has some type of film/ tint/ on it. Looks good but for some reason doesn’t cover full window. Cut out around the rear view mirror a bit too big.
is this standard from factory? Did dealer do this; and is the notches normal?
#24
That’s not a film or tint. It’s either the internal heat element or the internal heat attenuating material depending on what you got. The cut out area is so you can mount a toll transponder there. The dealer didn’t install anything.
I tried shatterx and got a chip a short time later. Don’t think it made any difference. Films like clearplex are also a waste of money since they wear out in s year or two and will cost more money.
Ben517 (01-01-2022)
#26
GrouseK9 (01-03-2022)
#28
Ben517 (02-18-2022)
#29
Found this explanation here: https://info.glass.com/metallized-windshield-purpose/
Metal oxide film can also be applied in a retrofit application.
What is a Metalized Windshield?
The glass in these windshields, sometimes installed in higher-end luxury vehicles, contains a thin layer of metal oxide that is applied during the laminating stage of the manufacturing process. This coating helps to block ultraviolet (UV) rays.Metal oxide film can also be applied in a retrofit application.
The Advantages of Metal Oxide Windshields
The layer of metal oxide reflects the sun and reduces the level of visible light. This provides a range of benefits, which include:- Reducing heat gain inside the car;
- Protecting the interior against ultraviolet rays;
- Reducing glare for the driver; and
- Assisting in de-icing and defrosting.
curb-optional (01-04-2024)
#30
