Body corrosion
im in auto collision right now.
if its just rust bubbles you just take lets say a 40 grit sandpaper and sand all the rust off about 3 inches past the corrosion area. then use a 3m brand body filler if needed. prime and paint. do not mask around the area for priming. it makes hardlines which make for hard sanding when you paint it.
this is the only correct way to fix rust without making it worse.
