New From AB! Transmission Service Upgrade Kits For Land Rovers & Range Rovers!
Old Jun 27, 2017 | 08:59 AM
AtlanticBritish's Avatar
LR Forum Vendor
Default New From AB! Transmission Service Upgrade Kits For Land Rovers & Range Rovers!
Servicing a late model Land Rover or Range Rover transmission is not for the squeamish. The original equipment service procedure from Land Rover involves the lengthy process of jacking the engine, unbolting the mounts and removing the exhaust...Not to mention, the fragility and care necessary with the sump and filter, since the OE replacement are attached as one piece.
Have No Fear! Atlantic British’s new transmission filter upgrade kits offer a much easier process. These modified kits with separate sump pans take a fraction of the time to install compared to the OEM design. What’s more, if you have a mechanic doing the service for you, you will save considerable money in labor, since the process is much faster. What’s more, the sump pans included in these kits are manufactured from durable steel, making them a quality upgrade over the original plastic OE pan.
Each Kit Includes:
  • New Land Rover Original Equipment Transmission Filter
  • Replacement, Upgraded Steel Transmission Fluid Sump Pan
  • Replacement Sump Pan Gasket
  • Gasket Fitting Bolts
  • Complete Printed Instructions
Alternative kits also available that include OE transmission fluid and sleeve.
These optional expansion kits include all of the above plus:
(7) Liters ZF Lifeguard Transmission Fluid
Transmission Sleeve (screw-in)
Transmission Service Upgrade Kits are available for the following Land Rover and Range Rover Vehicles:
  • LR3 / Discovery 3 | '05 - '09
  • LR4 / Discovery 4 V8 5.0 Liter | '10 - '13
  • Range Rover Full Size 4.4 (Jag Engine) L322 | '06 - '09
  • Range Rover Full Size 4.2 Supercharged (Jag Engine) L322 | '06 - '09
  • Range Rover Full Size L322 | '10 - '12
  • Range Rover Full Size Supercharged L322 | '10 - '12
  • Range Rover Sport | '06 - '09
  • Range Rover Sport Supercharged | '06 - '09
  • Range Rover Sport | '10 - '13
  • Range Rover Sport Supercharged | '10 - '13
Check out our Land Rover Master Technician, Doug, as he explains and shows how to complete this easier, streamlined transmission service!
__________________
Riviera
May 16, 2016 11:33 AM
Johnson Rods
Jan 30, 2016 04:13 PM
AtlanticBritish
Member Group And Special Buys
Mar 10, 2011 10:17 AM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
pch
Nov 1, 2008 12:30 PM
