Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
1996 LR 4.0 sub install need help
Old Jan 16, 2007 | 11:21 PM
mr mike's Avatar
Default 1996 LR 4.0 sub install need help
ok i have a 1996 LR 4.0 it has a clarion cd changer in it and the stock raido. My first ? is what wires do i tap in to to put a line converter in. i would liketo ad more subs and what wire do i use for a remote wire. next ? what size speakers do i have in my doors i was thinking that i night upgrade them to. OOOO how do i get in to the speakers do i have to take off the door panel or do the covers just pop off thanks for all the help in advance
Old Jan 17, 2007 | 11:15 PM
mr mike's Avatar
Default RE: 1996 LR 4.0 sub install need help
anybody ???
Old Feb 21, 2007 | 04:39 PM
okdiscoguy's Avatar
I have a 97. I replaced the door and rear sails with 4" Boston Acoustics. The 2 6 1/2's in the tailgate I just unhooked and ran the line to a new amp and sub. I replaced them, but it wasn't enough fo what I wanted. The low line to the amp is not low enough to usewith the RCA's, you have to use a line converter. If you are hooking up an amp, everything you need is there, besides the high amp + wire. either use the high in, or a converter. Oh, and FYI, I put 2 8's under the front seats. Plenty of room, but I don't have the changer there. If you do, you might have a problem.
P Carr
13
Apr 28, 2013 02:40 PM
TenMan1
May 7, 2012 02:22 PM
leddifer
Jan 30, 2010 03:15 PM
Classic89
Oct 14, 2007 04:46 PM
