Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
radio noise when charging devices
Old Jun 29, 2015 | 03:22 PM
TOM R's Avatar
Default radio noise when charging devices
not sure if this is noise or its blocking the signal somehow but i have a 3 socket adapter plugged into the cig lighter and when i plug in the usb to charge my phone its like the radio no longer gets reception unplug radios fine
do i need a noise suppressor for the cig lighter circuit?
Old Jun 29, 2015 | 10:00 PM
robertf's Avatar
you may want to try adding a ferrite bead around the wires going to the charging port. I don't know if this will solve it, but its on my list of things to try. Ios devices seem to be terrible about this, while an XM unit plugged in to the same port doesn't do this.
Old Jun 30, 2015 | 03:44 PM
TOM R's Avatar
ok you mean that plastic tube clamped around the wires on some devices?
Old Jul 1, 2015 | 06:44 AM
robertf's Avatar
yes, but the plastic is just a cover. they are iron. they are under $1 at any electronics shop ive been to
Old Jul 10, 2015 | 08:59 AM
TOM R's Avatar
i did order somne beads, but the issue resolved itself when i installed the power ports in dash, still using same usb charger but no noise?? guess it was the power splitter thing i was using
Mark G
Oct 29, 2012 09:02 PM
steve
Feb 18, 2009 12:02 AM
bonedoc
Jun 13, 2007 03:24 PM
sabsr1954
Oct 24, 2006 04:25 PM
RTLimo
Aug 15, 2005 12:42 AM
