2011 LR4 HSE LUX build thread - djkaosone
Old Jun 3, 2021 | 09:10 AM
djkaosone's Avatar
3rd Gear
Default 2011 LR4 HSE LUX build thread - djkaosone
A few people have asked, and I finally decided to create a build tread. I'll update this original post with links to stuff I did to my LR4.
2011 Land Rover LR4 HSE LUX
Santorini Black
Armor:
ASFIR Front Sump skid plate
ASFIR Gear skid plate
ASFIR Air tank skid plate
Terrafirma rock sliders TF818
LR3 2.7 TDV6 conversion:
EBC Orange LR3 Front and Rear pads
Britpart Front crossdrilled rotors DA4612
Britpart Rear crossdrilled rotors DA4614
TRW Front carrier SEH500012
TRW Rear carrier SXP500013G
Wheels/Tires/Suspension:
Stoptech Front and Rear stainless steel brake lines
Proud Rhino SYA with limiting straps
6mm emergency EAS tee fitting bypass
BMW X5 style 130 wheels
M14x1.5 60* conicle lug nuts
BFG KO2 255/70r17 (6)
Viair 400P tire compressor
Milton S-506 tire inflator gauge
Recovery:
Terrafirma A12000 winch TF3301 - https://www.landroverworld.org/threa...install.29560/
Terrafirma hidden winch tray TF097
Terrafirma/Britpart waffle boards DA5600
Factor55 Flatlink shackle 16k
Green Pin 3/4” D-Rings 30k
7/16 soft shackles 35k
3” x 6’ Tree saver 30k
Kartek 2” x 30’ woven recovery tow 20k
Electrical:
XS Power D3400 aux battery
Victron Cyrix 120A
Victron 75/15 mmpt solar controller
Lensun 110W 28V hood solar panel
Rocker switch panel 6 gang
5 rocker switches
Kenwood TM-281 modified
NMO dual band antenna
Baofeng UV-5R handheld ham radio
Custom antenna mount
Blue sea fuse block
Engel flush mount sockets
Aux cigarette sockets
Powerpole sockets
2 AWG wires
Engine:
Custom dual oil catch cans
-AN10 fittings
5/8 stainless steel hose
Removed exhaust resonator
Lighting:
Baja Designs Squadron-R fog amber light replacement - https://www.landroverworld.org/threa...5/#post-219487
Amazon 7” round led lights behind grill
Amazon 7” light bar under side roof rack
Amazon 6” amber led light bar (dust lights) under rear roof rack
Custom Led light strip under glow
Front Runner Outfitters 40” led light bar under rack
6k led interior lights
Cerakote headlight restoration
Overlanding:
Front Runner Outfitters full roof rack
Front Runner Outfitters dual jerry can holder
Front Runner Outfitters Featherlite roof top tent and annex
Front Runner Outfitters 2.5M awning with annex
KickAss shower tent
Engel anniversary 45qt mounted in 2nd row center seat
2nd spare on roof rack
1 gallon propane tank
Custom portable Eccotemp L5 hot water tank with auto prime pump
Bedslide
Misc:
Custom interior hoodliner storage - https://www.landroverworld.org/threa...storage.42619/
Custom under rack waffle board mount - https://www.landroverworld.org/threa...d-mount.42211/
Front seat molle brackets
Ram mount phone
Custom clear polycarbonate wind deflector
Manual rear hatch latch - (not mine) https://expeditionportal.com/forum/...rade-prevent-rear-door-failure-for-25.159873/
Proud Rhino OX hitch
HF 2T and 8T bottle jack
Maintenance (significant):
Timing chain tensioners - https://www.landroverworld.org/threa...g-chain.31050/
Timing chain guides
Both HPFP
Both MAF
O2 sensors
New transmission (2x)
New Front diff
Valve gaskets
PCV valves
Water pump
Oil cooler pipe
Front and rear crossover pipe
Coolant pipes
Thermostat
Walnut blast intake valves
Rear hatch actuator replacement
GAP IID Tool
iCarsoft i930
jtunio
Dec 11, 2020 03:13 AM
csohkrisztian
LR2
Dec 11, 2020 01:38 AM
Steve Selyutin
Apr 14, 2019 08:37 PM
luxury1
Jan 29, 2008 10:14 PM
GodSavetheQueen
Jan 9, 2008 12:15 PM
