Lil Jax Disco II build
Been late coming, but here is the recent build I have been working on. Finishing up the sound system so the daughter has a little bump going on.
Heading to The Shop
New Cannibal v8 Installed
New Center Caps
Intermission. Had a trip out of country that interrupted the process.
Getting ready for lift, ss brake lines, and wheels/tires
DynaMat entire roof
Reconditioned head liner
trying to seal the typical Disco Leak. Sealed the CRAP out of it
Getting new to me Style 2s ready for BFG KO2s
Blacked out Hood. Actual Paint Job
Almost Complete
Heading to The Shop
New Center Caps
DynaMat entire roof
Almost Complete
All things that have been done so far!
>>New Cannibal v8 (upgraded cam)
>>Oil Cooler Added
>>180 Thermostat
>>New Coil packs, plug wires, oil pump, water pump and about every other thing to bolt on the new engine!
>>Reconditioned/Rebuilt SAI pump and check valves
>>Replaced entire Airbox
>>Replaced battery cover
>>Blew out and cleaned entire SAI system
>>Various Coolant hoses replaced
>>New O2 sensors all around
>>New Magnaflow front y-pipe and Cats
>>New Radiator
>>All New Stainless Steel AB brake lines
>>New EBC Cross-Drilled and Slotted rotors and EBC Green Pads on all 4 corners
>>New Deka Battery
>>New Windshield (actually 5 new windshields, long story)
>>New Cowling
>>New A pillar covers
>>Painted and cleared flat mat blackout on hood
>>Reconditioned fender flares (took off, reconditioned and painted, put back on PITA)
>>Replace both shifter leather boots
>>Replace climate control bulbs
>>Repaired Ash/Coin trays
>>2" Terrafirma Medium Duty lift with All Terrain Shocks
>>D1 retention plate on rear
>>Terrafirma heavy duty Steering/Track rods with tie rod ends
>>Terrafirma Steering Damper
>>Terrafirma adjustable PanHard rod
>>Replace Hurricane 18" with 16" Style 2 Rims
>>BFGoodrich 265/75r16 All Terrain KO2s,
>>Replaced / New Wheel Center caps
>>DynaMat entire roof
>>Replace '03 roof bars with '04 roof bars (got a smoking deal on some good used ones)
>>Reconditioned HeadLiner
>>Cleaned, inspected, and permanantly sealed all leaks espically above windshield at corners. Smoked tested to confirm all leaks repaired.
>>Replaced ALL door lock actuators
>>Upgraded Lock Pin in Driver side door
>>Repaired two window guide wheels in actuators and lubed up tracks
>>Replace keyfob cover. ($10 fix to repair your worn buttons)
>>Reconditioned headlights/lamps
may have forgot something.
>>Oil Cooler Added
>>180 Thermostat
>>New Radiator
>>New Deka Battery
>>New Cowling
>>New A pillar covers
>>DynaMat entire roof
try D&D fabrications (D&D Fabrications: Engineering & Fabrication Services | Land Rover Specialists) they and cannibal seem to have a relationship
hahahaha, that's the long story! SafeLite replaced it back in '07. It leaked after they replaced it, had it replaced again, leaked again. They finally blamed it on the Sun roofs.
fast forward to this recent rebuild, we found they damaged the seams on the top corners where we found some hardened epoxy. Called them for the lifetime warranty. They told me to pound sand.
Put a nice post on their facebook page. Got a PM from their executive customer service department within 8 hours. They fixed the seams, replaced the windshields, repaired the headliner, replaced the overhead dvd player, replaced the cowling that was damaged during the install and the A pillar trims. Unfortunately, they replaced the windshield 4 times before they agreed the seams needed repairing, but that was their problem. Caused me a lot of delays.
I like to judge a company on how they react when everything goes bad, and I have to say, in the end SafeLite really stepped up.
jy3
06-04-2009 02:50 AM
