my 98 disco1
Old 04-07-2015, 05:56 PM
TOM R's Avatar
Yes brit part
Took the bumper off, there are holes in frame for UK bracket
Took bracket cut off bottom to match bumper
Used bolts to align bracket with frame holes, checked bumper fit, welded bracket to frame and hitch, removed bolts(they served no purpose but alignment)
Remount bumper
  #372
Old 04-07-2015, 06:34 PM
TOM R's Avatar
I also made this shelf and installed it, made it from a usps mail minivan cargo divider , I also plan to cover inside the windows in cargo area with same stuff
  #373
Old 04-08-2015, 07:01 AM
vegas99d1's Avatar
Nice shelf! Can you please post more pics of how you mounted it?
  #374
Old 04-08-2015, 07:50 AM
TOM R's Avatar
Piece of angle on each side screwed into the body panel with nut inserts from hardware store, then zip tied to home made cargo divider
The angle came with the divider I cut up, mind you the shelf flexes, its only for light stuff, blankets,pillows , tp , paper towels imo
There is a company that sells it , I copied from a pic, this is lighter then the screen in a police car divider as I tried that first
  #375
Old 04-12-2015, 03:56 PM
TOM R's Avatar
Built some lights for bumper since the factory ones are busted , 2" led on thin aluminum plate, plus my homemade stone guards to keep some fool from using the light cutouts as a foothold
  #376
Old 04-19-2015, 08:53 PM
TOM R's Avatar
Got abs unit deleted today, no more brake pull best I can tell
  #377
Old 04-19-2015, 09:49 PM
ihscouts's Avatar
Was it the right front? My right front has always pulled since I bought the truck. New calipers, rotors, no difference. Figured it was in the ABS Modulator block and was going to take it apart to see what's doing what.
  #378
Old 04-19-2015, 10:11 PM
TOM R's Avatar
Pull was weird , think it was pulling right, I had done lines and calipers and flush fluid, no help
  #379
Old 04-20-2015, 08:41 AM
TOM R's Avatar
Btw I ended up using the valvoline dot 3-4 synthitic hope it is OK since I flushed the entire system again
Only dot 4 I could find was a metal can quart with German writing at pep boys and it was expensive like double the valvoline
  #380
Old 04-20-2015, 09:25 AM
fishEH's Avatar
I've been using that Valvoline for years with no problems.
Quick Reply: my 98 disco1
