my 98 disco1
#31
ok i decided to mount a compass on the dash and to my suprise it always points north,turned on the compass in my cell and set it near the dash same thing so guess there is something magnetic in the center of the dash?
where do you mount a compass?
#32
today we decided to pull the console and remove the cdl shifter, what a fraking nightmare the console has been out and broke everywhere before so guess I will look for another in the jy next trip
we removed the cdl shift to find that even though it would go high low the cast ring that bolts to the shifter was seized to the h/l linkage
the cdl shifter was completely seized up on the left side like I have seen mentioned before, complete disassembly with help of a lead hammer
cleaned all rust and corrosion and lubed with red grease, I don't see where any amount of lube would have got this loose
the grease that was in there was brown and still good too bad it had all settled on top of the trans which is no help to the shifter
this nightmare took at least 3 hours, I hope it does not ever need to be done again
#33
correction the nightmare took closer to 5 hours since we snapped off the bolt in the cast ring h/l linkage had to drill and heat and luckily it came out
now the cdl moves super easy left right like 2 fingers easy and the lite comes on, the h/l was all cleaned and lubed but is still a little stickey
#35
thanks, work in progress, to bad it is a rust bucket, we did test out the cdl tonight for a few minutes off road climbed over some dirt mounds and it works very well since I am sure I would have been stuck cause we bottomed out on the factory running boards
so guess in the end it was worth the agrivation, now just wishing we had got the 2" lift
#36
I want one of those front brush guards also. (and a winch )
#38
there is a little spring in the latch assembly that goes bad that assists the actuator. springs are left right specific and tiny small
here they are on ebay Land Rover Discovery Door Lock Repair Spring 5 Door Set | eBay
