Operation Magpie.
Old Jul 22, 2019 | 10:29 PM
  #631
Saturnine's Avatar
Yah, i did as well.. Never again!
Old Aug 8, 2019 | 09:43 PM
  #632
Saturnine's Avatar
Nothing new to report
Rolled past 143k the other day and i need to do ball joints soon. I also think i have an exhaust leak where the manifold connects to the down pipe -- have gaskets but just need to install them.
ALSO.. Its expansion tank time. I was thinking about using a different one, i know that the e30 tank has been discussed but i actually found this on amazon..
Dorman Expansion Tank Dorman Expansion Tank
They make the fan blade i have installed and its good stuff.. For $13 or whatever, might be a better option. I was also considering something from the Mk3 VW's which is more of a sphere style but are fairly indestructible
Thoughts?
Old Aug 8, 2019 | 09:47 PM
  #633
As long as you can sort out the connections I don’t see why not.
I was looking at the tank in my 110 and thinking it’s to bad they don’t make a brass one like that for the Disco
Old Aug 9, 2019 | 12:45 AM
  #634
Richard Gallant's Avatar
@Saturnine we had a Disco 1 blow the tank on our 4 day trip seam blew out for about 1/2 the tank, he did have a cooling problem however, the "advantage" to the plastic tank is can fail form over pressure before gaskets go - with luck. of course your cooling system has to be pretty comprised for that to happen
Old Aug 9, 2019 | 10:15 PM
  #635
Saturnine's Avatar
Nah, this tank I have is just crappily made. I have probably plugged at least 3-4 cracks now with screws, cooling system was completely redone a year ago and still is working just fine. The tank i bought was probably sub $30 so you get what you pay for
Old Aug 9, 2019 | 10:25 PM
  #636
Saturnine's Avatar
This is the VW tank btw -- has the right connection at the bottom and the overflow at the top. Even has a sensor for when the coolant is low which i'm sure can be wired up to an idiot light or something Mounting can't be all that hard either..
Old Aug 18, 2019 | 04:39 PM
  #637
Saturnine's Avatar
More cracks in the expansion tank 🙄. I’ll probably just get one of Abran’s tanks and be done with it.
Greased the sunroofs and door latches along with double checking the aux fan worked. Had a few instances of the temps getting up in the upper 200-teens while sitting in traffic on 100+ days which was a little concerning
Still chugging along other wise!
Old Sep 2, 2019 | 10:02 AM
  #638
Saturnine's Avatar
Still waiting on replacement ball joint boots from Rimmer, im rather irritated. Its been almost 2 months and im hoping that the new joints arent going to get fubared because of ripped boots from shipping
Old Sep 2, 2019 | 08:37 PM
  #639
That sucks to hear
Old Oct 20, 2019 | 10:52 AM
  #640
Saturnine's Avatar
146k on the clock now, I'm procrastinating on doing ball joints and flushing the cooling system for.. no reason at all. Passenger front window decided to stop going down, seems to be hung up in the track or something -- window will roll down about 1/4" and then tilt forward and get stuck.
Passenger foglight has a bum connection that is intermittent so have to look into that.
Otherwise... all is well! Work has been nuts, getting ready to roll out a new model of EarthRoamer in the next few months so thats exciting..
