She is back!
#42
#46
#47
Yeah you could do the work yourself and probably save money but for me it was easier to just pay someone else to do it. However since it took so long I would have rather just done it myself. I'd recommend just buying the motor and installing it yourself. Companies like cannibal, great plains, or Atlantic British deal with these motors all the time and they know them up and down so I'd order a long block that way you're not worried about dealing with a machine shop that knows nothing about rover v8s.
cybercop (02-27-2015)
#48
The actual engine cost $5500 without goodies. That is about the price of any of the good remaned engines with top hat liners. The rest is shipping costs, labor, and other incidentals, which you will have no matter if you do it yourself or not.
By the time you take your engine out, strip it down to the block. Send the block off to a shop to have it worked over and top hats installed, take your heads and have them machined and rebuilt, then buy a new camshaft and all the other bottom end stuff, gaskets, and then all the incidentals you are going to find bad when you reinstall the engine, I think you will be at about $4500 to $5500. Then you still have to consider all of your labor, and you still haven't got a block and heads that have been through the rigorous inspection a Cannibal block and heads have been thru.
Plus, you get a 2 year warranty. Not a bad deal in my book!
#49
So that driveshaft I had ordered was for a Discovery 1... I called lucky 8 and they had a new one in the mail with a return shipping label within a few days. They really are a good company to work with.
Now she's 4wd just in time to head over to Hale Mountain offroad park. We spent 20 minutes driving down into a valley and 5 hours winch back out. I learned some things about the ARB bumper. It's terrible for repeated winching. You have to watch your cable very very closely otherwise it will bind up and aside from using another truck to pull out the cable there is no way to get it to spool out. Second is that unless you have modified your clutch you'll have to reach inside the bumper every time you want disengage the motor. All this led up to a nasty bruise on my arm and a badly kinked cable. All my issues can be overcome except the inability to access the winch drum easily.
I do like the ARB. I love how it looks and the amount of protection it gives as well as using the fog lamps....buuuut... if anyone wants to trade for a TR or RTE....
I also did a little more work to the roof rack lights. They are finally wired into a switch on the binnacle and only work with the ignition on.
I'd say they work pretty well. Now I really have to finish the dual coach batteries and water tank!
