Defender Talk about the Land Rover Defender within.
110/Defender brake master cylinder query
Old Jul 16, 2015 | 12:45 PM
rupert's Avatar
3rd Gear
Default 110/Defender brake master cylinder query
Hello All - I have a 1989 Land Rover 110 that originally had a 2.5 TD engine in it but which is now powered by a 200 Tdi. I'm replacing the brake master cylinder, and note that when I withdrew the cylinder from the servo, it had a rubber sealing ring around the base of the part hat inserts into the servo. However, the replacement master cylinder I have did not come with a sealing ring.
Looking at various LR parts websites, I don't find any master cylinders with rubber seals to go between the cylinders and servos, and both those parts are sealed units anyway, so my assessment is that there normally isn't a sealing ring between them and that a previous owner added one on my vehicle at some point for whatever reason. Can anyone advise me on this? Am I correct that there isn't normally a rubber seal between the master cylinder and servo on a 110/Defender.
Thank you.
fitch11
Dec 29, 2007 05:07 AM
colton
Dec 26, 2007 11:33 AM
colton
Dec 10, 2007 12:14 PM
larry99discoI
Aug 22, 2007 02:35 PM
leebuhrul
Feb 26, 2006 03:38 AM
