1994 Defender 90 300tdi cyclic metal chirping in transfer box
I changed the double cardan front prop shaft which came with new UJs. Greased everything on it to be safe.
Getting a metal chirp in three ways...
1 - Starting out on a turn
2 - Letting off gas after accelerating
3 - Accelerating
Chirp stops when I press in clutch pedal
Stuck my head out the window when chirping starts and it sounds like it’s coming from transfer box. Will be changing oil in gearbox, transfer box, and diffs next.
What do you suppose I should expect if chirping continues after oils are changed?
Thanks!
3 - Accelerating
Thanks!
Mario De La Torre
05-04-2017 11:41 AM
