Cyclic chirping sound from drivetrain
Old Sep 13, 2017 | 05:15 PM
RoverSeriesInf's Avatar
4wd High
Default Cyclic chirping sound from drivetrain
I need some help diagnosing the source of this noise. Cyclic chirping from drive train, sounds like a sparrow, but is fairly quiet.
chirpchripchirpchirp
Observations:
1. Increases with vehicle speed, not engine speed, no noise at idle
2. Very quiet, only audible with windows down, between 5 - 25 mph
3. Front prop shaft is the grease-able type (I assume PO replaced it)
4. Both prop shafts have been greased twice since January, including the 'slave grease nipple' (ha!) on the front shaft. I used a ton of grease.
Wheel bearing? Transfer case bearings? Diff bearings? Transmission output bearing? Prop shaft u-joints? Where do I even start?
To do:
1. Get under car and check for play in prop shafts
2. Re-grease prop shafts and re-check for noise
3. Jack up wheels and check for wheel play
I don't have the budget to replace all the wheel bearings and front prop shaft at once.
Thanks for any troubleshooting advice.
Old Sep 13, 2017 | 06:13 PM
OffroadFrance's Avatar
Observations:
To do:
IMO it's the driveshaft. Don't drive it until it's fixed or replaced.
Old Sep 13, 2017 | 06:14 PM
OH+D's Avatar
4wd High
The sparrow type noise is almost always a driveshaft - either universal joint or centering ball.
Adam
Old Sep 13, 2017 | 06:22 PM
mollusc's Avatar
Can you try coasting slowly in neutral with the engine off, with someone walking beside? That might help you narrow down the location.
Old Sep 13, 2017 | 06:28 PM
PalmettoDisco's Avatar
Drive shaft going bad. Like said, u-joint or centering ball. If it fails it can knock a hole in the transmission case. $$$$. Rebuild yourself, or take to driveline shop, or buy replacement (OEM or aftermarket, typically aftermarket better bang for the buck). Test for u-joint, listen for a clunk when placing into drive from neutral back to neutral to reverse. A worn sloppy u-joint will clunk between opposite directions.
Old Sep 13, 2017 | 07:15 PM
ZGPhoto's Avatar
It's 100% always the front driveshaft as OH&D said
Old Sep 13, 2017 | 08:25 PM
LR03NJ's Avatar
Drive shaft 1
Drive Shaft 2
I just got driveshaft 2 this afternoon and installed.
Old Sep 13, 2017 | 09:16 PM
I'd go with number 2 as well and not be the test mule for that one.
Old Sep 13, 2017 | 09:54 PM
OverRover's Avatar
100%! And at least you know L8 will stand behind the sale.
Old Sep 13, 2017 | 10:32 PM
Exactly
