Defender Talk about the Land Rover Defender within.
1994 defender nas backfires in to the intake
Old Jun 29, 2012 | 11:36 PM
Mapolo's Avatar
Unhappy 1994 defender nas backfires in to the intake
HELP PLEASE
I HAVE A 1994 DEFENDER NAS 3.9 V8 THAT BACKFIRE INTO THE INTAKE AND MISSES AND HAVE NOT POWER, HOWEVER AS SOON I DISCONNECT THE MAF SENSOR IT DRIVES LIKE IT JUST TO BE. ALL THIS AFTER A SHORT CIRCUIT IN A RELAY AND IT BURNED THE GROUND WIRE AND THIS GROUND WIRE BURNED THE GROUND TERMINAL 40 AND 14 FROM THE ECU. I DID REPAIR THE GROUND IN THE ECU BUT NOW I HAVE THIS PROBLEM, HOW EVER I TEST THE MAF, TPS, COOLANT TEMP, FUEL TEMP AND ALL OF THEM ARE OK, THEN I WENT FAR AND REPLACE ALL OF THIS SENSOR FROM MY DISCOVERY I THAT IS RUNNING FINE AND IT DID NOT MAKE ANY CHANGE; THE DEFENDER HAVE NEW SPARK PLUGS, TAP, ROTOR, SPARK PLUG WIRES, FUEL FILTER, AND IT IS PERFECTLY ON TIME. WHAT REALLY PUZZLE MY IS WHY IT RUN GREAT WITH OUT THE MAF.
BEFORE HAND THANKS FOR ALL YOUR HELP.
Old Jun 30, 2012 | 06:01 AM
threalassmikeg's Avatar
Have you try swapping a known good 14cux ecu?
Old Jul 1, 2012 | 10:15 AM
Mapolo's Avatar
Thanks Mike
No I have not try a different good ecu, however I do have a 1997 Disco 1 with a 3.9 and I think its the same ecu but it bolts different and I also have one ecu from a range rover 3.9. Do you think I can try any of this ecus?
Thanks so much for your help
Old Jul 3, 2012 | 05:23 AM
you should be able to plug any 14cux into it. it should start and run
and at least get you on track.
Paul Grant
May 13, 2025 10:24 AM
Jason Andrew
Nov 27, 2014 09:25 AM
jeffrudy
Jul 4, 2009 03:59 PM
birdhunter61
Oct 6, 2008 09:04 AM
URBANOFFROAD
Apr 16, 2007 01:28 AM
