Defender Talk about the Land Rover Defender within.
2.5l petrol engine carburetor replacement
Old Sep 19, 2008 | 01:04 PM
cadare's Avatar
Default 2.5l petrol engine carburetor replacement
Hi friends, first post here. (Often searching for tips, but never posted due to ultra slow net speed in my country)
I have a '92 110, with the 2.5l. petrol engine. It was a mess when I got it. The previous owner put a tiny FordMo.Co. carburetor on it, and it is definitely not going to work. I'm looking to replace it.
What do you recommend as a replacement? I'm hoping it is something I can find while I'm on holiday in the States. Any suggestions?
Thanks.
Old Sep 27, 2008 | 07:11 PM
Adz's Avatar
Adz
Default RE: 2.5l petrol engine carburetor replacement
Ripped this off another forum in the UK...
http://smg.photobucket.com/albums/v3...rb%20pictures/
If your carb looks like this it's the stock item. The 2.5 petrol was never particularly powerful and even if you whack a big carb on there, meddle with the head a bit and change the cam profile I suspect "dissapointing" is going to be the way you'll describe it
Old Sep 28, 2008 | 11:44 AM
cadare's Avatar
Thanks. The guide is for the 2.5l engine '86-'90 with a Weber 32/34 dmtl carb. I think that will work.
I don't expect a lot more power, but I'm hoping for an even distribution over the bulk of the engine speed. Also for maintenance purposes, I don't care what the power output is as long as I get the appropriate fuel-air mixture into the cylinders.
Thanks a lot!
Old Sep 28, 2008 | 05:43 PM
Adz's Avatar
Adz
No worries... where are you in the World? Only a mate of mine is about to remove a 2.25 Petrol from a 90 to put a Tdi in. It's the same carb on that and he might be prepared to part with it if you're local
firefighter
Sep 2, 2017 03:23 PM
grandkodiak
Jun 12, 2013 08:40 AM
roverdisco1017
Jun 28, 2012 06:48 PM
RoverBuild
Jun 1, 2012 07:27 AM
oferl
Jan 27, 2010 03:20 PM
