Defender Talk about the Land Rover Defender within.
issue with clutch?
Old Aug 21, 2022 | 10:24 AM
turski's Avatar
Default issue with clutch?
Hi all... I am new to forum but hoping you can help
I completely rebuilt my 1962 series 2a petrol so am mechanically capable....
I have just inherited an 200Tdi 110 (pre immobiliser).... I have managed to start it and it drives not very well... Aside from my series car, I have not much experience with these diesel Defenders.... The first problem I have is the clutch... it has good pressure going down and can change gears (only 1st 2nd and reverse tried at very low speeds).... gear change isn't great but doesn't crunch.
When I put in gear and release, even slowly, there is is a fairly large jerk as the car takes off, so there is no subtle engine engine engagement. Plus if I take out of gear and leave in neutral and release clutch I can hear a rattle from the clutch area.... the rattle goes as I depress the clutch.
The bite of the gear is about half way through pedal travel when I release.... so its not to the floor or anything.
This may have been me, but as its, a fairly violent jerk into gear engagement and take off, I released the clutch slowly, and I noticed a fait bit of smoke coming from clutch area. happened after only one slow clutch release.
Obviously there is an issue and I wondered what the experts here might thing the best way forward is.
Is the clutch gone?... or is there some sort of adjustment?
Old Sep 4, 2022 | 06:21 AM
The Deputy's Avatar
Sound like it's time to replace clutch. Your clutch disc/plate has springs on it that soften the engagement slight...sounds like some fell out and are rattling around in bell-housing.
elorenzof
Defender
Jun 2, 2022 01:53 PM
staffs007
Sep 28, 2021 03:40 PM
Marco Jeroen Pieren
Mar 18, 2020 02:17 PM
markdeg
Nov 28, 2018 09:29 AM
robandmandii
Nov 8, 2005 04:29 PM
